The Vogons Game Server is Back Up!!!
First post, by Jade Falcon
Rank BANNED
BANNED
MY game server is back up. New Games will be added soon! QA3 is the next game to be added.
Ut99 server is back up and going..
The IP Is: 24.208.177.52
The Password: See my Interests on my profile page.
Server Name: Vogons
RULES:
No Cheating.
No giving out the password to non vogons members.
You must use your vogons user name.
No trying to brake the server, hack it or the network it is on.
Have Fun!
EDIT:
If you have any ping/latency problems shoot me a pm with your IP and I'll setup a static route to help.
I still have a few tricks up my sleeves for the server end of things to drop the pings, but I done about all I can at this point shy of paying for better internet. If you have any other problems let me know.
Planed Server Down Time:
None for now.
Reply 2 of 22, by Jade Falcon
Rank BANNED
BANNED
Thanks. My new mobo has a better NIC and I did a firmware update on my router so pings will be better if it were not for running the server in a VM 😢
pings are down by about 3ms with the firmware upgrade and new nic.but the VM could steel the 3ms
Reply 3 of 22, by SquallStrife
Tried it just now, over 260ms latency, unplayable. 🙁
(I'm in Australia though, so it's not your server's fault!)
Reply 4 of 22, by Jade Falcon
Rank BANNED
BANNED
Sorry about that, not much I can do. However you could try to connect to the server via the IP. That may help a small bit.
Reply 5 of 22, by ultimate386
Tried getting on yesterday, but my ping was 1000+
Got back on this morning and it was a much more playable 150, give or take.
I am playing on my K6-2+, Voodoo3, Win98SE box 😎
Thank you for hosting! I'm planing to setup a Starsiege Tribes server here later on down the road.
AMD386/IIT387DX40, 32MB, ATi Mach64, AWE64
Compaq Prolinea 4/33, 32MB, Tseng ET4000, PAS
AMD X5, 64MB, S3 Virge/Voodoo1, AWE64
AMD K62+550, 256MB, Voodoo3, AWE64 Gold
P3 1.2Ghz, 512MB, Radeon 7500/Voodoo2 SLI, SB Live!
Reply 6 of 22, by Jade Falcon
Rank BANNED
BANNED
ultimate386 wrote:
Tried getting on yesterday, but my ping was 1000+ Got back on this morning and it was a much more playable 150, give or take. […]
Yeah, I don't have a dedicated network for the system and a family member was eating up all the bandwidth, I still have to setup QoS.
I did some tests the other day via speedtest.net, from the server to London UK is a about 90-105ms, from the server to different places in Norway is around 150-200ms. But the way the game works will add around 20-25ms. So if your pings the server may be 100ms but in the game you may get 125ms. I'm not that skilled with the back end of networking so I don't know what the case is, I have a few ideas but that's it.
Anyway if your in the USA you should get a round 75-150ms, if your over seas you should get around 125-250ms.
Reply 7 of 22, by ultimate386
Albuquerque, New Mexico
Reply 8 of 22, by Jade Falcon
Rank BANNED
BANNED
That's about 1,600 miles from the server. Not all that bad when you consider how bad my internet service is.
I really need to upgrade.
Reply 9 of 22, by Jade Falcon
Rank BANNED
BANNED
Updated OP: added planned down time.
Had some fun last night, oddly I found a few glitches in the game to render the redeemer useless.
If you jump wile firing a charged up bio gun at it will blow up on the person that fired it.
Oddly we both shot a redeemer at each other and it went off right next to etch other and both were left unharmed. 😕
Also I don't consider changing the FOV as cheating. To change the FOV open the game's console and use the setfov command to adjust the fov.
I use setfov 100. I believe 90 is stock.
Reply 10 of 22, by ultimate386
That was me! Good times! 😵
Reply 11 of 22, by Jade Falcon
Rank BANNED
BANNED
Having some heat problems with the chipset on the new motherboard.
Had to reboot the server, it's running a disk check now.
Edit:
Looks like the file system is went way out of whack when the system locked up from the over heated chipset. Good thing I have a second drive with the vm boxes backed up to incase if I need to start over. But it looks like I got it all fixed.
Reply 12 of 22, by Tetrium
I gave it a go briefly yesterday, but my ping of around 260 or so (this is what my ping to the server was displaying in the server list) made it very hard to play. Even almost drowned in that goo when I was going for that flak cannon 😵
But this is quite common when I join any server located in the states.
Perhaps it might be an idea to (somewhere down the road) try a game where razorsharp connection latencies don't matter as much?
My retro rigs (old topic)
Report spammers here!
Reply 13 of 22, by Jade Falcon
Rank BANNED
BANNED
Sure can. Maybe aoe? Have any ideas?
Reply 14 of 22, by Tetrium
Let me think about it.
TA might be a good one, but so is Spring (basically a free 3D version of TA, but it does require a more modern rig if using lots of bots) but at least it doesn't depend too much on ping. I've actually ported many units from TA to spring for my personal mod and it won't even require a dedicated server.
Reply 15 of 22, by Jade Falcon
Rank BANNED
BANNED
What's ta?
Reply 16 of 22, by DracoNihil
Total Annihilation
― Κυνικός Δράκων
Reply 17 of 22, by Jade Falcon
Rank BANNED
BANNED
DracoNihil wrote:
I might have that game. I know I have a few games like it.
I load up a few VMs for RTS games. Once I get quake3 VM up this weekend.
Reply 18 of 22, by Jade Falcon
Rank BANNED
BANNED
I have total anihilation I will add it soon.
I also got a new chipset heat sink in, but it's not the best fit and abit loud. I'll get a better one soon.
I only paid 4$ for it. It cools the chipset a lot better but it still runs on the hot side.
Reply 19 of 22, by gdjacobs
Tribes 2, man!
