awe64 - no sound
Reply 40 of 106, by Robhalfordfan
the reinstall.com is part my third party boot manger to dual boot with windows 95
isn't hymen.sys needed for windows 3.11
Reply 41 of 106, by dr_st
Yes, hymen.sys...
When you are solving a strange problem, you try all sorts of things. It's quite possible you are dealing with a hardware issue, but to know for sure you want to eliminate all software components that can possibly affect the environment.
Reply 42 of 106, by Robhalfordfan
dr_st wrote:
You don't need CTCM in CONFIG.SYS.
You don't need DIAGNOSE or CTCU in AUTOEXEC.BAT.
I don't think any of this should hurt, but it definitely does not help, so maybe it's best to take it out.
I took out the lines out from config and autoexec.bat and now the aweutil says awe initialization failed
Reply 43 of 106, by j^aws
Rollback, so that the AWE64 initialises. Ensure you have this file in your:
"C:\Your AWE64 directory\DRV" directory, and you should see a file called CTMIDI.DRV.
There are various versions. Ensure it is the one compatible with AWE64. There should be one somewhere in the VOGONS drivers sections.
Reply 44 of 106, by Robhalfordfan
I do have that in sb16 driver directory
Reply 45 of 106, by j^aws
No, check that the file physically exists in the above directory and it is the version for the AWE 64.
Reply 46 of 106, by Robhalfordfan
I do have it and how can I tell what version is it
Reply 47 of 106, by j^aws
Check the file date. My working one is dated 6/6/1996. Older ones may work. Check VOGONS drivers - there should be various versions.
Reply 48 of 106, by Robhalfordfan
mine says same date
Reply 49 of 106, by j^aws
Do you have "MFBEN" jumper enabled on the soundcard?
Reply 50 of 106, by Robhalfordfan
yeah I do
Reply 51 of 106, by j^aws
Have you ran CTCU - it's a utility, and verified all the AWE64 ports are available without conflicts, including EMU8000 and MIDI ports?
Reply 52 of 106, by Robhalfordfan
Yeah here a pic of the testing of audio
Reply 53 of 106, by j^aws
Have you a pic for the EMU and MIDI?
Reply 54 of 106, by Robhalfordfan
is that gameport and wavetable
Reply 55 of 106, by j^aws
Yes, check all sections and verify.
Reply 56 of 106, by Robhalfordfan
The gameport test is greyed out but that set I/O range 200-207 (with no other choice available to change range) and pic is the wavetable test and the I/O range has no other choice available to change to
Reply 57 of 106, by j^aws
Can you type "pause" on a new line in AUTOEXEC.BAT, after the last relevant soundcard entry and post a screenshot?
Reply 58 of 106, by Robhalfordfan
Two screen shots for all sound card thing on startup, top pic is start and sec pic is end of sound card startup
Reply 59 of 106, by j^aws
In your CONFIG.SYS, move all DEVICE= and DEVICEHIGH= entries AFTER DOS=HIGH.
Immediately after DOS=HIGH, add in a new line, DOS=UMB
Post your current CONFIG.SYS.
