First post, by maddrock
I've just downloaded Dosbox so I can play some of the games I remember when I was young, and the first one on my list is Kings Quest 7 by Sierra.
However when I load the install file on Dosbox, and use the option 'use your machines extra memory' (which seems to be the only option i can use) I get the screen i've saved as an attachment:
The attachment KQ7DOS.png is no longer available
Then it just exits the installer. How do I get past this bit? Apologies if its an obvious question, I'm new to Dosbox.
I'm using Windows 10 btw!
Reply 2 of 4, by maddrock
Thanks, though it asks for the CD location and I only have virtual files, no actual disk. I tried converting them into an ISO and mounting it but it didn't recognise it!
Reply 3 of 4, by Jorpho
So, you downloaded this illegally from somewhere? You can obtain a legal copy from https://www.gog.com/game/kings_quest_7_8 that should work without any problems.
Otherwise, it is generally pointless to attempt any troubleshooting as your "virtual files" may be incomplete or otherwise corrupted.
