First post, by user222
ZSNES crashes DOSBox often, because of the problems with pagefaults.
it crashes with:
Exit to error: Pagefault didn't correct page
Reply 6 of 10, by wd
Rank DOSBox Author
DOSBox Author
Loading works fine here, didn't crash a single time.
Try to replace the cwsdpmi with a different
version, and be sure to mount a c-drive (or not).
> Why bother when the newest ZSNES runs on windows xp and linux?
Why not 😉
wd
Reply 9 of 10, by `Moe`
zsnes uses SDL just like DosBox, so it should run wherever dosbox runs.
Of course you are right, tracking bugs is nice, but the ultimate goal is to _play_, and using a native port is easier, faster and generally more enjoyable (screen resolutions, hardware acceleration, etc.).
Reply 10 of 10, by Serious Callers Only
I think zsnes dos is the only one with a debugger yet. And since dosbox can run on mac and zsnes can't ... well ... this is only one example, i'm sure there are more.
