Roland SC-88VL Windows Compatibility?
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby JeffBai » 2017-1-25 @ 23:35
Currently consider purchasing a Roland SC-88VL for use on my laptop (which does not have MIDI interface), so I will be likely to take advantage of the Serial MIDI interface. The following I have found through my brief researches...
- Roland SC-88(VL) should be compatible with SC-55MkII (but some instruments are mapped differently with SC-55).
- I could use a Serial MIDI driver for Windows 95, while using SoftMPU for games in MS-DOS.
Then I started digging around for drivers and found it at an Edirol page (via Internet Archive), and found the driver over here:
http://web.archive.org/web/200508291030 ... ivers.html
And looking at the table, the Windows Serial MIDI driver to use is this:
http://web.archive.org/web/200508291030 ... me9895.exe
But the problem is SC-88VL was not mentioned in the corresponding Readme file (http://web.archive.org/web/200508291030 ... readme.txt)... Only "SC-88" and "SC-88 Pro" are listed. Is it that Roland SC-88VL has some incompatibilities in regards of Serial MIDI interface? Or is it just unnecessary concerns?
Thanks in advance.
JeffBai
Re: Roland SC-88VL Windows Compatibility?
Postby BloodyCactus » 2017-1-26 @ 02:22
88VL is just a smaller standard 88. you should have no issues. I have an sc88vl (white) but not tried it via serial midi, only using roland usb-midi on windows and direct midi in dos via gameport
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
User avatar
BloodyCactus
Return to Sound
Who is online
Users browsing this forum: No registered users and 4 guests
