First post, by Sandi1987
I have Dual Boot Windows XP SP3 + Windows 98 Second Edition on my AMD Athlon XP computer. I want to install XP SP2. Can i install on the same partition as Windows XP SP3 without lossing Dual Boot?
Reply 1 of 6, by PhilsComputerLab
Take an image of the drive and try it out.
Reply 2 of 6, by Gamecollector
Err... You want to replace SP3 to SP2? Or something else?
WinNT4 and later detect Win9x and correctly add it to boot.ini.
Reply 3 of 6, by Sandi1987
Yes.
Reply 4 of 6, by Jo22
Just curious, why do you need SP2, as well ? Don't get me wrong, I still really like SP2:
It's quick, stable and very compatible - including with certain types of utilities.
But if your rig is powerful enough for SP3, then... why ?
Do you plan to install another type of XP (Home/Pro or other language) which comes with SP2 ?
Sorry, I'm just curious. You don't have to respond to my post, if you don't like to. 😀
Reply 5 of 6, by Sandi1987
I don't want SP3 because too many Updates. I delete Windows XP SP3 and install SP2 on the same partition as SP3 and Dual Boot work.
Reply 6 of 6, by 95DosBox
Yes as long as you already installed Windows 98 First. If you install XP and then 98 second it will kill the XP boot loader.
You can also make a 3rd partition and install XP SP2 on it. XP differentiates between each partition with a separate drive letter. Vista and later do not and force the OS to appear as C:.
That is one reason why XP reigns supreme.
Also in the Boot.ini you will see it specifies a different partition drive number if you install it on the 3rd partition.
