First post, by sideburns
I recently installed Heroes of Might and Magic II on my Linux computer (Which distro doesn't matter.) running under Dosbox. All is going well, except for one thing: the volume is pegged at max, and adjusting it doesn't do any good. If I have to, I can adjust the computer's sound before running the program, and put it back when I'm done, but that's just a kludge. Does anybody know how to make changes like that work, either from inside the program, or by editing a configuration file?
Reply 1 of 5, by mrau
linux can, depending on factors, change the volume for just one program - that might solve the problem?
Reply 2 of 5, by zirkoni
In DOSBox:
mixer master 10:10
or some other values that result in acceptable sound volume. Then make a batch script to execute that command and start the game so you don't have to write it every time.
https://youtube.com/@zirkoni42
Reply 3 of 5, by sideburns
I don't know how to set volume on a per-program basis in Xfce, but I know where to ask. As far as using mixer, I already have an [autoexec] section in the .conf file that sets everything up and runs the program, provided that it's a Dosbox command. And, I run that from a shell script, so I can put it in their if needed.
Reply 4 of 5, by zyga64
If you're using Pulseaudio (all modern distros use it by default), you can use 'pavucontrol' which can control volume per-program. Check if DOSBOX can be set to output audio by Pulseaudio.
I think something like mentioned in 2nd answer might help to redirect SDL to Pulseaudio: http://askubuntu.com/questions/79944/dosbox-has-no-sound
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 5 of 5, by sideburns
Thank you, but as it turns out, using mixer to set the volume to 30:30 was Just Right.
