First post, by superfury
I'm currently using the following code for low-pass and high-pass filtering all my generated signals:
Header with all typedefs:
#ifndef FILTER_H
#define FILTER_H
#include "headers/types.h" //Basic types!
typedef struct
byte isInit; //Initialized filter?
byte isFirstSample; //First sample?
float sound_last_result; //Last result!
float sound_last_sample; //Last sample!
float alpha; //Solid value that doesn't change for the filter, until the filter is updated!
//General filter information and settings set for the filter!
byte isHighPass;
float cutoff_freq;
float samplerate;
} HIGHLOWPASSFILTER; //High or low pass filter!
//Global high and low pass filters support!
void initSoundFilter(HIGHLOWPASSFILTER *filter, byte ishighpass, float cutoff_freq, float samplerate); //Initialize the filter!
void updateSoundFilter(HIGHLOWPASSFILTER *filter, byte ishighpass, float cutoff_freq, float samplerate); //Update the filter information/type!
void applySoundFilter(HIGHLOWPASSFILTER *filter, float *currentsample); //Apply the filter to a sample stream!
#endif
Code for processing the selected filter:
#include "headers/support/filters.h" //Our filter definitions!
filter->isHighPass = ishighpass; //Highpass filter?
if (filter->isInit || (filter->cutoff_freq!=cutoff_freq) || (filter->samplerate!=samplerate) || (ishighpass!=filter->isHighPass)) //We're to update?
if (ishighpass) //High-pass filter?
float RC = (1.0f / (cutoff_freq * (2.0f * (float)PI))); //RC is used multiple times, calculate once!
filter->alpha = (RC / (RC + (1.0f / samplerate))); //Alpha value to use!
else //Low-pass filter?
float dt = (1.0f / samplerate); //DT is used multiple times, calculate once!
filter->alpha = (dt / ((1.0f / (cutoff_freq * (2.0f * (float)PI))) + dt)); //Alpha value to use!
filter->isHighPass = ishighpass; //Hi-pass filter?
filter->cutoff_freq = cutoff_freq; //New cutoff frequency!
filter->samplerate = samplerate; //New samplerate!
filter->isInit = 1; //We're an Init!
filter->isFirstSample = 1; //We're the first sample!
updateSoundFilter(filter,ishighpass,cutoff_freq,samplerate); //Init our filter!
INLINEREGISTER float last_result;
if (filter->isFirstSample) //No last? Only executed once when starting playback!
filter->sound_last_result = filter->sound_last_sample = *currentsample; //Save the current sample!
filter->isFirstSample = 0; //Not the first sample anymore!
return; //Abort: don't filter the first sample!
last_result = filter->sound_last_result; //Load the last result to process!
if (filter->isHighPass) //High-pass filter?
last_result = filter->alpha * (last_result + *currentsample - filter->sound_last_sample);
last_result += (filter->alpha*(*currentsample-last_result));
filter->sound_last_sample = *currentsample; //The last sample that was processed!
*currentsample = filter->sound_last_result = last_result; //Give the new result!
But it's running very slowly, even on fast systems(Intel i7 4.0GHz processing a 3.57MHz(Game Blaster) PWM signal by low-pass filtering). Is there a way to optimize this to be fast? Or is this already as fast as it can be?
UniPCemu Git repository
