First post, by xandman
ok this is weird 'cause phantas 1 and GK2 run fine once u do that trick where u bypass the system test but phantas2 keeps comming up with errors saying it hasnt been installed properly, and it cant install all the files, if i didnt know any better id say the disc is damaged but its in perfect condition and the last time i ran it on my last windows 98 comp it ran fine. now when i try to load it it just comes up with a panic button 999 resource bla bla bla - make sure all your cd drivers are properly installed - which basicly means [from previous info i gathered] that it cant find all needed files. can anyone help? cheers
