First post, by riku
Heya everyone again.
Have decided to change my board to a different one, main reason is FAKE cache chips was installed there, removed them enabled cache and pc says cache is on on bios screen but 🤣 they are no chips. so i guess not even worth to try putting real cache chips there because dont know if the motherboard breake them 🤣
Fake cache chips where these, i tested on other mainboard and they are fake PICTURE HERE
The board what is in place its a 486 SIS496 Pictures here
It has 64M of ram, 120mhz am-dx4 cpu, scsi, s3trio(changed from voodoo rush, no point keeping voodoo, it is slow), sb16, 0 L2 of cache see pics there cachechk.
Main reason why i need change this is the finding up about fake cache, and unable to get working a Gravis ultrasound, the pc wont boot at all when card is on isa slot(even alone) it post but wont boot. it will not hang it just stall there, i can go to bios by pressing DEL button on that point.
What about to change to other mainboard. My needs are (upgrade for 5x86 133mhz cpu and pci slot)
well i do have some options:
486_ATC-1425B(FAIL) This board is a fail for unknown reason wont post
486_AUVA_CAM_25_33_U0 this board support only 50mhz cpu
486_Biostar_mb-1433 this support only 50mhz cpu and has issue with cache. not yet complete inspected the problem. has no PCI
486_DTK_PKM-0037S this board never got cache working, so its out of the question need more inspect, IF is good... also no PCI and no 72pin
486_HIPPO_DCA2(untested) well bios missing, pre-tried prom one but dead for now, not sure no time to play around i dont have anyway EDRAM
486_M33_SIS works fine has OPTi chip, only bad has no PCI slot, and no 72pin memory support (i can however live with 32M of ram).
486_MS4131(FAIL) fail fo unknown reason, wont post
486_PV1-486SP3(untested) tried m27c1001 prom no success waiting for reprogram prom come from ebay
486_UMC8881 this board has everything, 72pin, vlb, pci, cache works but if i remember correct manual says 100mhz is maxium CPU so.... 🙁
486_UMC8881_2 works but again manual if i remember correct says 100mhz maxium cpu speed.
So any tips? i just want most versatile motherboard of 486 to replace my fake thing. even most of them i need solder new battery or dallas that is not a problem.
pictures above boards can be found here: https://pilvi.titanix.net/s/IudeDiIpmZ3ezTx?path=%2FEmolevyt
Thanks already 😀
Reply 1 of 19, by Brickpad
Which 5x86 CPU? AMD or Cyrix? The AMD and Cyrix chips run at 3.45v, so you'll need a board that can handle voltage.
Reply 2 of 19, by Skyscraper
The Asus PVI-486SP3
Good things.
With the latest BIOS you can run all socket-3 CPUs (3.xx BIOS versions won't work with all BIOS chips, replace the BIOS-chip if it's too old)
Working PS/2 mouse header!
VLB + PCI
Well documented
Good quality
Good layout
Good CPU, memory and cache performance
Less good stuff.
Not the best video performance, especially with PCI video-cards (~10% slower than the fastest boards).
Maximum amount of cache is 512KB and you need 4x "128k x 8" chips to get more than 256KB (~$15 on Ebay).
This is in my opinion the best 486 board out of the 15 or so I own so the Asus PVI-486SP3 is what I would use.
Reply 3 of 19, by Ampera
Skyscraper wrote:
The Asus PVI-486SP3 […]
The Asus PVI-486SP3
Good things.
VLB + PCI
Well documented
Good quality
Good layout
Less good stuff.
Then again, more than 256k of L2 cache on a 486 is really not that well needed.
Reply 4 of 19, by Skyscraper
Yea I agree, I use 256KB cache with 2x16MB memory and even Windows 95 is very snappy.
Winbond W29EE011 is the flash chip I used to flash the latest BIOS for the Asus PVI-486SP3. It's not one of the two listed supported flash chip models but works perfectly and it's easy to find on Ebay for a dollar or two.
Reply 5 of 19, by riku
I have now am4x86 120mhz AMD
Im thinkin to upgrade later to amd 5x86 or so
Have ordered sst29ee chip for flashing. Tried 27c1001 and that was no post, will the pvi-486sp3 post without backup battery? The aka "coin cell" ?
Reply 6 of 19, by Skyscraper
I would thnk it would post without a coin cell.
As long as the sst29ee is a 128K x 8 (1 Mbit) chip with 5V programmng voltage it should support the latest BIOS. Be sure to remember to jumper the motherboard for 5V BIOS programming voltage if your old flash chip was one with 12V programming voltage. TH99 lists the jumper settings for BIOS programming voltage, the manual does not.
Reply 7 of 19, by kixs
Ampera wrote:
The Asus PVI-486SP3
Good things.
VLB + PCI
Well documented
Good quality
Good layout
Less good stuff.
Why not? If motherboard supports more and you have the correct chips, go ahead 😀
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 8 of 19, by Skyscraper
Wth the Asus PVI-486SP3 using 4x "128k x 8" chips might actually not be faster than using 8x "32k x 8" chips. I think I have seen some tests showng that 8x "32k x 8" cache chips for some reason wins out over 4x "64k x 8" cache chips so the benefit of having twice the amount of cache could be negated by using only 4 chips. I guess this could differ from board to board.
The Asus PVI-486SP3 do sadly only have 4 DIP 32 sockets and 4 DIP 28 sockets so using 8x "64k x 8" or 8x "128k x 8" chips isn't an option.
If someone is going to use NT4 then upgrading to 512KB cache is more important to get 64MB memory fully "writeback" cached.
With motherboards that have 8x DIP 32 sockets upgradng to 512KB cache is a no-brainer as "64k x 8" chips are cheap and more easy to come by. 😀
Reply 9 of 19, by lvader
Some of the 486 boards with fake cache actually perform pretty well and are very functional due to the chipsets being used. I have no complains with my faketastic 80486 VIP
Reply 10 of 19, by riku
the performance of fake cache board is very good, its fast. but again reason why i found the fake cache thing was GUS not working. so there is something going on.. it has sis chipset and it is ok. ofc now i find out about fake cache i going to switch it.
I managed to find out my eprommer programmer wont support 1M chips, thats is reason i could not get 27c1001 working. i think it should work like flash. but it is write protected. Wednesday i going to borrow a bigger prommer if that has support. while waiting those 1meg 29EE flashes going to try normal proms.
EDIT:
i rip out 29EE010 from an old non working pentium board. again my prommer will prom it but well not as suppose... it will erase it, and prom random stuffo on it, but not as it suppose 🙁
Reply 11 of 19, by riku
Heureka!
After numerous tries of proms etc this one needed at least 20 times reprogram, but finally
Then not started... started to change cpus and it seems amd 66 was the heureka one, with intel was no luck, maybe jumper setting... i got finally picture!!
Have no idea if mobo is ok need to test it out later today:) but im so happy all efford pay back now 😀 😀
Bios is 306 as i readed 307 has problems
EDIT SORRY OF PIC Wrong way, i just posted with mobile phone fast, clicking it will display correct orientation.
Reply 12 of 19, by riku
put a 3volt CPU in then jumpered according manual then regulator smoked 🤣??
searched google came this post: Best PCI performance... okey it seems need find a transistor now. it is a pnp one. anyone else hving issues installing 3volt cpu on this board?
Reply 13 of 19, by riku
Got the board working again, now with right cpu.
thanks again all for help
More repair pictures here: https://pilvi.titanix.net/apps/gallery/ ... ETROSETUP)
also installed 256kb of cache, dunno if i should keep that or go 512? i have 64M of ram, but it is possible to decrease to 32M.. have windows95 and old dos games, its plenty for it
there is the mosfet switch replace with IRF: (was the switch, not the pnp transistor what acts like a regu)
The attachment IMG_0210.JPG is no longer available
anyone knows are this ram modules FPM ??
The attachment IMG_0215.JPG is no longer available
Need some tips about installing graphic card, should i just go with PCI s3 trio 64v+ or put a VLB one?
The attachment IMG_0217.JPG is no longer available
More pictures on graphic cards here:
https://pilvi.titanix.net/apps/gallery/s/Iude … tteja%2FVLB_GPU
Reply 14 of 19, by Tetrium
The SIMM looks like a 32MB one, the part number suggests it's FPM. Just google the part number (sorry I'm a bit lazy atm), but you could also just try them in your board.
Or try in an old Pentium board that works with EDO. It should display whether it's EDO or FPM.
This might be a nice site to read up on the SIMMs http://www.chipmunk.nl/DRAM/DRAM.htm
My retro rigs (old topic)
Report spammers here!
Reply 15 of 19, by Skyscraper
riku wrote:
Got the board working again, now with right cpu. thanks again all for help […]
With 256KB cache 32MB memory is best because then you can run the L2 cache in Write Back mode and still have all memory cached. 32MB is enough for the kind of Windows 95 games that run well on a fast 486.
The Asus PVI-486SP3 is probably a little bit faster with a VLB card, I think your Western Digital card would be really fast. I'm also using Windows 95 with my Asus PVI-486SP3 system but I'm using a Matrox Millenium II 4MB PCI card to get good picture quality at 1024*768 in Windows. For me picture quality is more important than getting the small performance increase a fast VLB card provides over a PCI card with this motherboard.
Reply 16 of 19, by riku
thanks for the answer, it is unsure if it fpm, i tried google. thats i asked here. it is yes 32M one.
i do have a pentium board under test, but that one is not showing if it edo or not.
I removed other 32M, so pc has one simm of 32M. after little struggling i got cache + cpu WRITE-BACK Working!!! it needed to do odd things, jumpers and change cache rams. so 32M is maximum cacheable memory, so i removed other simm.
would be nice if someone has more optimal settings? 😀
Anyone please could point me to where i can get 1024 cache modules cheap? if i upgrade to 512k, then i can use 64M
About VLB card, i have wester digital (untested) have no idea of vram it is wd90c56-7x chip. i will see if that works.
Reply 17 of 19, by Skyscraper
riku wrote:
thanks for the answer, it is unsure if it fpm, i tried google. thats i asked here. it is yes 32M one. i do have a pentium board […]
The Asus PVI-486SP3 does not support EDO memory so if the memory works it's FPM
(Correct me if I'm worng as I'm not 100% sure. On other SIS 496/497 chipset motherboards it depends on chipset revision but I can not remember seeing anyone getting EDO memory working with the Asus PVI-486SP3)
I dont know much about the Western Digital VLB cards but my 1MB ISA card is very fast. I think I have read good things about them but testing all cards and seeing what card performs best and gives a good picture quality is the best option.
Reply 18 of 19, by riku
i will take edo simm and try it out, it is simple as that.
the WDC 90C31 is VLB card, google has only info about 16bit ones 🤣
Reply 19 of 19, by riku
edo ram just done bad to the post screen 🤣, can confirm not working :DDDD okey got my answer, it is FPM
