Reply 700 of 5159, by blurks
King_Corduroy wrote:
Beautiful terminal. Has such a 60's/70's futuristic look.
Here's a contemporary ad (late 70's/early 80's?):
http://www.vintagecomputing.com/wp-content/im … inals_large.jpg
Reply 701 of 5159, by King_Corduroy
Your image isn't loading, I've had a couple mid 80's WYSE terminals in the past and a 1979 Dasher D200 (hopelessly broken). The Dasher was beautiful, looked like it was designed by Maserati or something. 🤣
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 702 of 5159, by Skyscraper
During the time I was inactive here on Vogons I still checked to local electronic waste dumpster now and then.
When tidying up the livingroom today (which in fact is more of a a storage room at the moment) I stumbled upon two motherboards I found some months ago.
The motherboards are an Asus A7V Socket A board and a Lucky Star 6ABX2V i440BX Slot 1 board with unknown CPUs. I hope the Lucky Star board har a 2Mbit BIOS as I then have a suitable Tualatin BIOS for it otherwise I will have to find a new flash chip. I found this Pentium 90 CPU together with the motherboards and also alot of other hardware but I do not actually remember exactly what, probably the cards and drives from the computers the motherboards belonged to.
The attachment Dumpster find Asus A7V REV 1.02 and Lucky Star 6ABX2V VER 1.2 with unknown CPUs plus a Pentium 90 SX968.jpg is no longer available
The motherboards looks to be in good condition but I have not tested them yet.
Reply 703 of 5159, by elhaya
today I found a Compaq in a local dumpster near my synagogue. Unfortunately, it is missing the CPU.
A while ago I found an IBM keyboard
Reply 704 of 5159, by deleted_Rc
yawetaG wrote:
^ That case looks suspiciously like an older version of the case of my ill-fated AMD Duron system, which died of a power supply not able to supply enough juice to run the computer under load...
Its an AT case, so quite old already nut these cases look prettige common. Its a lovely small case, required abit of modding tot be satisfactory (was unstable so put in an additional rivet at every corner connecting 2 layers of steel together and cut out a hole for 120mm intake fan in the front). This case will hold a beast soon
Reply 705 of 5159, by Matth79
elhaya wrote:
today I found a Compaq in a local dumpster near my synagogue. Unfortunately, it is missing the CPU. […]
Would that be a S478 P4 ?
I'll be gutting a similar system for a core 2 build (original S478 guts all work)
Is it allowed to offer bits for postage cost?
Reply 706 of 5159, by Carlos S. M.
What is the HP model, there are 4 different models using the same case:
HP D530 - Socket 478 P4
HP DC7100 - LGA 775 P4
HP DC7600 - LGA 775 P4/PD
HP DC7700 - LGA 775 P4/PD/Core 2
I listed all models and the supported CPUs, they also supports the Celeron varaints of the mentioned CPUs (Celeron/Pentium variants in the case of Core 2 in the DC7700). The DC7700 might support Core 2 Quad with a newer BIOS
Reply 707 of 5159, by elhaya
model dc7100C/P4-530/80hnd/256F/4 HEB
Reply 708 of 5159, by Carlos S. M.
Well, seems the best CPU you can use is the Pentium 4 670 3.8 GHz with the newest BIOS, idk if the Pentium 4 661 Cedar Mill will work on that
Reply 709 of 5159, by elod
Check for BIOS updates, if I remember right it does support it. I have a mainboard from these systems, they are nice for testing stuff as they are mounted on a large metal plate.
Reply 710 of 5159, by Asaki
I found an Aureal Vortex 2 =)
Itching to try it out, but I'd have to put my Win98 machine back together first.
Reply 711 of 5159, by Half-Saint
Another good day for trash. lol […]
Another good day for trash. 🤣
Gonna make this into a 2000's gaming machine. 😁
Make sure to check that PC for bad caps. Dell machines from that period are notorious for having bad caps.
Reply 712 of 5159, by rein_ein
Found this crapware yesterday,an Asus P5S800-VM and Gainward 6600GT.
Mobo visible have some bulged caps,non tested yet,video card have noisy fan but works.
Reply 713 of 5159, by Skyscraper
Well the Asus P5S800-VM "find" seems like an opportunity to hone your recapping skills! 😀
The caps having to do with the CPU VRM circuit seems fine at least. I hate those small green craptastic caps. I have plenty of boards with just that kind of bulging, leaking shitty caps. It's a pain that they look a bit like Sanyo caps so when you browse Ebay and the pictures are taken from a distance and/or are out of focus it's hard to tell the difference.
Reply 714 of 5159, by probnot
Picked up some stuff from friends' places today.
First load (not pictured) was 2 Commodore64s, 2 floppy drives, 1 power supply, 2 joysticks, and a bunch of games on floppies 😁 I've never played with one before so this has me excited!
Second load was from a friend who has a woodshop in his basement...kinda mediocore stuff, but I might find a use....definitely need to bring out the air compressor
- Savage4 8mb from a Compaq (I think this is from the tower)
- ASRock P4S61, with what I think is a 2.4Ghz P4 ...this may even be from my old media center I gave him years ago...
- Mac Mini, unknown specs (not pictured)
- Tower w/ Asus A7V mobo, 256mb, unknown CPU, 40GB Seagate, and a Windows Millenium key! 😵
Reply 715 of 5159, by nforce4max
Also that screen has delaminated, the safety glass covering the CRT has separated from the actual CRT. […]
Just wiped it down and it looks better though admittedly.
Fixing the CRT isn't hard but you have to really take your time if you ever decide to remove the safety glass or the picture tube will implode, some old timers out there are still doing work on old TVs so get in contact with someone who can help you out. The glue or silicone behind the safety glass never has aged well, one trick to soften that crap up is to put the picture tub in a black trash bag and put it over a trash can with the neck down then let it get hot in the sun so the glue softens up. Use chop sticks or something along those lines to gently add some pressure between the safety glass and the tube but keep it even as either the glass can shatter or the tube implodes. Square tubes are more likely to implode so keep that in mind.
Once cleaned up use some clear double sided tape in the corners to hold the glass in place then fill along the edges with fresh silicone, be sure to get rid of any dust before you finish. Everything else should clean up well enough to look decent to good.
Reply 716 of 5159, by Jade Falcon
Rank BANNED
BANNED
^this^
I don't like doing it, but it does work.
Reply 717 of 5159, by mr_bigmouth_502
probnot wrote:
Picked up some stuff from friends' places today. […]
Dude, that's a Touch Systems box. I used to see those all the time in my youth. Are you Canadian?
Reply 718 of 5159, by SW-SSG
That was my thought, too. There's a supermarket nearby me that still runs a few of those boxes for the tills. Same Enlight cases and Touch case badges.
Reply 719 of 5159, by probnot
Yup, I am. I used to see these all over as well, but I always though they were local. Didn't realize they were Canada-wide...
