My 3DMark03 Mega Thread
First post, by Standard Def Steve
Welcome to the 3DMark 2003 Mega Thread!
We have a very long 3DMark01 Mega Thread with just about every hardware configuration imaginable. 3DMark01 is very sensitive to single threaded CPU and memory performance. It also takes a pretty serious performance hit on anything that isn't Win2000 or XP.
3DMark03 is much harder on the video card than 3D'01. In fact, 3D'03 is even more GPU intensive than 3DMark05 and 06! With a modern Core i5/i7 processor, you typically won't see any major CPU bottlenecking until you get to the higher-end GTX 900 and R9-390 video cards. Even then, you can usually shift the bottleneck back to the GPU just by increasing the resolution to 1080p. With 3DMark01, you'd still be completely CPU limited even at higher resolutions. Another nice "feature" of 3DMark03 is that it doesn't take a performance hit with newer versions of Windows.
Like the 3D'01 thread, there will be no fancy schmancy charts here. Just post images of your 3DMark2003 scores--that's it! Please try to include result details in your images. I'll go first. 😀
i7-4930K @ 4.6GHz, GTX970 @ ~980 performance levels, 32GB quad-channel DDR3-2400 CL10:
A64 3700 (OC 2.75GHz), x1950Pro AGP, 2GB DDR-400
Pentium III-S @ 1575MHz, GeForce 6800GT, 2GB DDR-300 CL2
Pentium III Coppermine @ 1125MHz/150FSB, Radeon 9800 Pro, 512MB PC133 CL2
PIII-866, GeForce FX5200, 512MB PC133 CL2
PIII-550 (katmai), FX5200, 512MB PC100 CL2
Athlon X2-3800 (OC 2.4GHz), 8600GT @ 8600GTS, 4GB dual-channel DDR-400 CL2.5
Athlon X2-3800 (OC 2.4GHz), HD4670 PCIe, 4GB dual-channel DDR-400 CL2.5
C2Q Q6600 (OC 3GHz), HD5770, 8GB dual-channel DDR2-667 CL4
C2Q Q6600 (OC 3GHz), Geforce 6800GS PCIe, 8GB dual-channel DDR2-667 CL4
A64 3700 (OC 2.64GHz), 6800GT AGP, 2GB dual-channel DDR-440 CL2.5
A64 3500 (2.2GHz), 7800GS AGP, 2GB dual-channel DDR-400 CL2.5
C2D T5600 (1.83GHz), GeForce 9800GT, 8GB dual-channel DDR2-667 CL4
Opteron 185 (OC 3GHz), GTX 260, 4GB dual-channel DDR-400 CL2
A64 3200 (2GHz), Radeon X600SE 128MB, 1GB single-channel DDR400
PIII-550 (Katmai), Radeon 9250 PCI, 512MB PC-100 CL2
Celeron 2.6 (Northwood), Radeon 9250 PCI, 2GB DDR-266 CL2.5
P4-532 (3.06GHz HT), Mobility Radeon 9000 IGP, 1GB DDR-333 CL2.5
Core Duo T2500 (2GHz), Mobility Radeon X1600 128MB, 2GB dual-channel DDR2-667 CL2.5
Reply 1 of 81, by Standard Def Steve
Here's how the GTX 560 scales with different CPUs:
Pentium D 830 (3GHz)
Athlon X2-3800 (2GHz)
Pentium E2220 (2.4GHz)
Core 2 Duo E6600 (2.4GHz)
Core 2 Quad Q6600 (OC 3GHz)
Reply 2 of 81, by Standard Def Steve
Let's take a look at how much Intel IGPs have improved over the years.
Celeron 1.7GHz, Intel Extreme (i845GL), 1GB DDR266
Atom N470 (1.83GHz), GMA3150, 2GB DDR2-667
C2D T5600 (1.83GHz), GMA950, 4GB dual-channel DDR2-667
C2D E7500 (2.93GHz), GMA X4500HD, 4GB dual-channel DDR3-1066
Atom X7 Z8700 (Surface 3), Intel HD iGPU, 4GB dual-channel DDR3-1600:
i5-3317U (Surface Pro first gen), Intel HD 4000, 4GB dual-channel DDR3-1600:
Reply 3 of 81, by Standard Def Steve
Here's a P3-1000 @ 1125 with an x800XT. Not sure why the CPU score is so low with this one. Even the PIII-866 w/ FX5200 gets a higher CPU score.
Reply 4 of 81, by Tetrium
Link to the 3DMark 2001 page (just for reference) and added this page to the Interesting Vogons Threads page on Vogons wiki (even though this thread is kinda short 😜)
Dunno if there was already a thread about 3Dmark 2003, but the fact that it's more a GPU benchmark is interesting in itself and chances are this thread will be picking up in the future.
My retro rigs (old topic)
Report spammers here!
Reply 5 of 81, by falloutboy
It's not my result, found it here http://www.overclockers.at/benchmarks/k6-3_un … ighlight=radeon
Definitely a GPU benchmark.
AMD K6-3, 400MHz (4.0 x 100 MHz)
Tyan Trinity 100AT (Via MVP3 Chipset)
2x128MB Kingston PC100
Radeon 9800Pro Catalyst 4.2
D3D & OGL Quality: Balanced
OS: W2k Sp3
IBM DTLA-307030
3DMark 2003 score: 2754
Reply 7 of 81, by agent_x007
dottoss wrote:
Pentium D-965 Extreme @ 4.66GHz, Quadro FX4800, 4GB dual-channel DDR2-8500 CL5: 39021
As a fellow owner/user of the legendary heater know as Pentium Extreme Edition 965 (OC) I HOPE you are using water cooling and have a badass motherboard to run it @1,55V 😁
Nice score, but how much of that ~1,55V stays after putting load on CPU ?
For comparison, here are two of my own scores :
"Cheap" MB (w/Win 7 SP1 x64) : Z4FYWic.png
And going mad (w/PCI-e 2.0/DDR3/Win 10 x64) :
PS.
That's really not true for Win 10 x64... but I guess it's still "in beta" and I'm just a "beta tester" 😜
Reply 8 of 81, by dottoss
A fair amount of v-drop: however, i have disabled the load Load-Line Calibration.
I can OC it up to 5ghz but then it requires around 1.7v and it will eventually shutdown thermally. It`s stable up to around 4.9GHz at somewhat safe voltages but stable 5.0GHz seems to be out of reach for this particular 965.
Cooling: kelvin s36
Motherboard: Asus P5Q-Deluxe
Reply 10 of 81, by agent_x007
Well, "X" series simply has two full PCI-e x16 slots available for SLI/CFX.
P35 doesn't have PCI-e 2.0 and X48 is a higher binned X38.
Best MB for this chip is the one with best VRM cooling - that's why I bought Rampage Extreme 😀
1,7V for 5GHz ?
Holy...
I simply put in BIOS 1,66V on Vcore (Vdroop ~0,1V), 1,35V on VTT and 1,65V on PLL 😀
With 1,55V on NB and 1,65V on RAM, I can do that Win 10 score.
And like You I have to turn off my Load Line Calibration (it gave me black screens...).
Have you tried going 1600MHz+ and lowering multiplier ?
Also : ALWAYS check VRM temps while in benchmark.
My P5K64-WS is a solid P35 board, but what it lacks is VRM cooling (at least when paired with this monster after OC).
Only thing that "X" has are two electricaly "x16" PCI-e 2.0 slots.
PS. I cool mine with Thermalright 120 Ultra Extreme with 4k Delta FFB1212EHE Fan on top 😉
My max core/fsb clock for now is 5,1GHz at 425MHz [1700MHz] : LINK
Reply 11 of 81, by Standard Def Steve
falloutboy wrote:
It's not my result, found it here http://www.overclockers.at/benchmarks/k6-3_un … ighlight=radeon […]
OS: W2k Sp3
IBM DTLA-307030
That's awesome! I just wish he would have tried the CPU tests on that.
66.6K--that's a great score for Netburst! My 3GHz Opteron 185 could only do 52.5K with a GTX 560 and WinXP. Now I'd like to retest it with a GTX 680 and Win7. For some reason XP always seems to produce lower CPU scores (but not as bad as Win10! 😳 )
Reply 12 of 81, by dottoss
Thanks, I will look for an Asus rampage. The CPU draws a hefty amount of current during full load, so I guess the more VRM cooling it has, the more it can push before it being deteriorating to the CPU and/or the MB. The P5Q-Deluxe has no setting for the Command rate and defaults to 2T, does the Rampage has this in BIOS?
Reply 13 of 81, by dottoss
agent_x007 wrote:
Well, "X" series simply has two full PCI-e x16 slots available for SLI/CFX. P35 doesn't have PCI-e 2.0 and X48 is a higher binne […]
Yes, I've tested it, it borks out as soon as I hit 416 FSB, and from 410 FSB to 416 FSB I need to increase the volt like crazy. I think it's the CPU that is the limit, but let's see when I get ahold of an Rampage board 😀
Reply 14 of 81, by agent_x007
VRM cooling can be misleading tho.
For eample, my P5K64-WS has a pretty good VRM cooling (on pics).
BUT, because top one is mounted on plastik pins (instead of metal screws) and has no heatpipes, it cannot make good contact with MOSFET's underneath when I put heavy cooling on my CPU (PCB gets bend over the CPU socket area to the point of visible gap can be seen between VRM heatsink and MOSFET's themselves).
That's how I had throttling on CPU @ 60C on it.
More current = more heat - true.
But, more MOSFET's = less heat (because current in split between all of them).
MOSFET temps are critical when they get around 90-100C.
If they aren't properly cooled, they can blow up under load.
That's why I always check temp of PCB edge closeset to MOSFET bank.
If I can't hold a finger to it for more than a 10 sec. MOSFET's are probably overheating.
^I had this problem with P5K64-WS and Pentium XE 965@5GHz.
Since CPU couldn't drop speed or Vcore, it used "STOP" instruction to not overheat it.
Performance dropped, but VRM didn't blew up 😀
@up Did you play around with Strap's and Performance Level and FSB Voltage (VTT) ?
Reply 15 of 81, by agent_x007
Hmm... I don't know ~66k is a bit low.
Give me a sec...
OK, I think I got this 😀
457.03 KiB
74k seems about right, won't you agree ?
Reply 16 of 81, by Standard Def Steve
That's actually fairly amazeballs for a PEE (lol...pee). Both the score and the 5.1GHz.
I paired up my GTX970 with a Phenom X6 1090T at 4069MHz. Score was a bit lower than I expected. I didn't think a Ph2 @ 4GHz would bottleneck a 970 that much in 3D'03.
Reply 17 of 81, by Standard Def Steve
Dredged up from the massive pit of benchmark results on my file server, here's a crappy Geforce GT635 with a Core i7 3770 (3.4GHz/3.9Turbo).
The CPU score's a little on the low side (even less than the 4GHz Phenom II I posted above), but that's probably because I was running it on the Win10 Technical Preview.
Reply 18 of 81, by buckeye
My result with a Core2 Duo 3ghz 2GB DDR2 Geforce 7950GT.
Going to try 3DMark06 next, may not be pretty.
    349.28 KiB
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 19 of 81, by Standard Def Steve
Messing around with a slow 4CoreDual-SATA 2 board.
C2D E6600 2.4GHz/1066, 4CoreDual-SATA2 (VIA PT880 Pro) 2GB DDR2-533 3-3-3-9, onboard audio, XP SP3
With GeForce 6800GT AGP:
389.98 KiB
With Radeon x1950Pro AGP:
396.44 KiB
With Geforce 9800GT PCIe (1.1 @ x4)
426.41 KiB
