Moonstone
First post, by SilverFang
Ok. I've been up all night now. Trying to get moonstone working. Yes, im a noob big time on DOSBox and everything there is whit computer programs. Anyway. I don't know why moonstone doesn't work. I've tryed whit everything there is. But the problem is that I don't understand nothing about DOSBox. (and all other programs you need to have) Do you have to type in something/do something when you start the program?
I also have downloaded alots of other programs in:
http://www.classicgaming.com/moonstone/emulation.htm
Wtf does "mount" mean? (im not so good on english)
Please. Someone help me. Im desperate... 😳
//musskit@hotmail.com
Reply 1 of 10, by eL_PuSHeR
*sigh* Why noobs always tend to do the more difficult things *sigh*
Have you read the documentation?
There are also some cool DOSBox guides on this forum. Read them.
Reply 2 of 10, by Snover
heh heh, mount. heh heh heh. 😉 </dork>
Yes, it’s my fault.
Reply 3 of 10, by MiniMax
Rank Moderator
Moderator
DOSBox Guides
_________________
Reply 4 of 10, by Kilrogg
Hello !
I can't run Moonstone too. I do know what "mount" means. Acutally, I understood most of the setup readme when I read it.
The thing is, after setting my drive and all that stuff, when I type "cd moonstone" (which is my directory), All I get is a "unable to change to moonstone".
Could someone help me ?
Thanks in advance !
Reply 5 of 10, by MiniMax
Rank Moderator
Moderator
Please explain what "setting my drive and all that stuff" means.
_________________
Reply 6 of 10, by HunterZ
1. Did you type C: by itself to switch to the virtual c drive before attempting to change the directory?
2. DOSBox doesn't support long filenames, and "moonstone" is longer than 8 characters.
Reply 7 of 10, by emodel
1. Firstly stick the Moonstone directory at c:\moon (remove Moonstone folder but cut moon part out and put it in c:)
2. Run DOSBox and type the following... mount c c:\moon
3. Then type c:
4. It simply remains for you to type ms.exe
5. Wahey - no more "Insert Disk A" messages!
Quoted from the site u downloaded moonstone from.
What a genius i am !!!
Latest dosbox cvs on windows xp sp3
Reply 8 of 10, by Kilrogg
Thanks everyone, I'm such a n00b, I figured out what my problem was a bit after posting by searching a little more on the forum : too long folder name.
Now, the only issue is : I can't get DOSBox to emulate sound correctly (all I get is no music and horrible sounds... not coming directly from the CPU, but still cheap sounds)... This game has no setup, so I can't configure the sound settings properly.
Does anyone know a proper DOSBox sound setting for Moonstone ?
Reply 9 of 10, by emodel
No music here either, but sounds are perfect.
(with default dosbox settings)
moon.cfg is sounblaster by default so its okay
Reply 10 of 10, by Kilrogg
Even with the default settings (soundblaster16), I can't get the sounds to play correctly...
Have any clue of what I should do ?
I have no other old game that I tried with Dosbox to compare and see if all the games have sound issues on my PC, so don't ask, unless you think that's really important to know that...
