First post, by GiSWiG
I'm installing Windows 98 on an Athlon64 system on a SATA drive. I first put in a floppy, do fdisk then a full format without /Q. I do expect lighting speed from this system but I was expecting a full format taking minutes and not seconds. Even on an even faster system, a full format should take longer on a 120GB hard drive, at least a few minutes.
This is the first time I've used a SATA drive for Win98. Is this normal?
Steamer/GOG-er: ASUS Crosshair IV Formula | AMD Phenom II X6 1100T 3.7GHz all cores | Mushkin 8GB DDR3 RAM 1333 w/ 6-6-6-18 1T | Dual AMD Radeon HD 6850s in CrossFireX | X-Fi Titanium | Dual-boot Windows XP and Vista
