Reply 5340 of 31480, by brostenen
Kamerat wrote:
I would worry more about running two VLB cards at 40MHz than overclocking a 486 by 21%. 😉
Qurious... What could potentially go wrong?
Reply 5341 of 31480, by cyclone3d
Mainly just instability. Some VLB cards will do 40Mhz fine, some wont.
That being said, I never really had a problem when running the 40Mhz fsb when I had a 486 VLB setup with a VLB video card.
And if the board specifically supports the DX2-80, then it should be fine with the 40Mhz fsb as that is what is required for the DX2-80.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5342 of 31480, by brostenen
Thanks. Good to know that stuff won't go defect/break when doing multi VLB-Cards and 40mhz. 😀
Does it help setting waitstates on the VL-Bus, if some instabillity show up?
Reply 5343 of 31480, by cyclone3d
Not sure. I never had more than one VLB card at any given time.
YMF7x4 Guide
Reply 5344 of 31480, by TheMobRules
Adding wait states may help when trying to run more than one VLB card at bus speed > 33MHz, though it's no guarantee it will work. There's usually a couple of jumpers on VLB motherboards which may help with that:
- One is for adding wait states, as you mentioned
- The other generally has 2 positions, <=33MHz and >33MHz, setting it to >33MHz can also help
Reply 5345 of 31480, by Evert
I bought this computer at a thrift store for R250 (roughly $25 USD). It originally came with an AMD K6-2 500MHz, 128Mb PC-133 RAM, 4Gb Fujitsu Hard Drive, a broken CD-ROM drive, an Avance Logic ALS120 sound card and an onboard Trident Blade3D graphics card. I disabled the onboard Trident and replaced it with a PCI Riva 128 (Vipper V330). I also removed the Avance Logic sound card and replaced it with an ESS 1869F. It came with an original copy of Windows 98SE and Office 2000. I sanitized the Fujitsu drive using DBan and reinstalled Windows 98SE.
Reply 5346 of 31480, by fcm
Wow!! I had this case model on a Pentium 133 and upgraded to a K6-2 + Tekram MVP4 board!! Never seen a fastest Super7 machine, I don´t know what it had 🤣
Pentium MMX 233@266| M537DMA | 64MB SDR | Trident 9685 4MB TVOut | SB Live! 5.1
2x Pentium III 1000EB | CUV4X-D | 1,5GB PC133 | TNT2 Pro GA-660 | 80GB HDD | Audigy
XP-M 2200+ | A7V600-X | 1GB DDR400 | Radeon X1650 Pro AGP | WD 80GB SATA
Reply 5347 of 31480, by ODwilly
Instead of the e8600 I ordered an e6750, price difference was $3 shipped vs $14. Ended up swapping out the e6300 with that, swapped the 2gb of 667 with 4gb of 800, and threw in a passive 8600GT. 1080p Youtube now only consumes half the ram and cpu, Instead of maxing everything out. Inspiron 530 now gets another 5 years or so of life 🤣. Stock 300watt Bestec PSU has a bad secondary cap, not causing any issues yet tho. Swapped in a high airflow Adda 80mm instead of the crappy slow Jamicon, so hopefully that helps a bit.
Reply 5348 of 31480, by oeuvre
Pulled out the CDROM drive from my Gateway 2000 and replaced it with a 40X regular IDE CDROM one. The one it came with was a Sony CDU31A-GD 2X CDROM which uses a proprietary 34 PIN ribbon cable (which is included). But I don't have any sound cards that support it.
Reply 5349 of 31480, by brassicGamer
Worst case scenario you end up with data corruption because the controller can't write data reliably to the disk. Not such a problem with a test system I suppose. The DX/50 was pulled from sale soon after it was released because it was running too hot or systems were unstable. Later on some VLB cards included jumpers that allowed you to choose the bus speed (<33MHz or >33MHz) and motherboards provided those jumpers for wait states. Lots of tweaking is required but, with the right combination of components, some patience and some luck, you should be able to build a kick-ass system.
Reply 5350 of 31480, by xplus93
Decided to run dell diagnostics on my XPS R450 because it was acting buggy. Ended up migrating to a new HDD. I think the one I put in it was the one from my computer when I was eight. Installing voyager elite force on it right now.
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 5351 of 31480, by brostenen
Nice... 😀
I will probably go for that 486dx2-80 in this system after all. I have it allmost finetuned as it is, right now.
It gives me some 47.6 in 3D-Bench 1.0 and 47.4 in 3D-Bench 1.0c. That with the dx2-66 (WT) and 128k-20ns cache.
I recieved the 512mb CF card today, and used most of the day, to install drivers and trying out games.
I tested the Transcend card, using Speedisk, and read/write-rate are both some 2,8mb/s. 😜
Doom is still a bit slow, so I will see if my dx2-80 will make the perfect solution.
It might just be too fast for games such as DynaBlaster, Syndicate and Cannon Fodder.
Time will tell if the 66 is the way to go, or the 80.
Reply 5352 of 31480, by cyclone3d
And remember, you can always leave the DX2-80 in there even if you need 50Mhz or 66Mhz.
All you have to do to change speeds without opening up the system is to run a few jumpers or even on/off switches to the front of the case from the jumpers on the motherboard.
Then when you want to change speed, you can change the speeds on the fly... may be sketchy with VLB cards installed. To be safe, just turn the computer off before changing speeds.
To be super fancy, you could get one of those old red LED displays that is configurable through jumpers and run the switches through there. Basically the same exact thing as an old computer that had one of those with a "Turbo" button. All the "turbo" button did was change the fsb of the motherboard on the fly.
YMF7x4 Guide
Reply 5353 of 31480, by Skyscraper
I ordered the underlings to bring me my loot. Now I just have to forget that this service exists so I don't order unnecessary crap.
$13.95 + $23.79 = $37.74 . $37.74 x 8.83 = 333 SEK. 25% VAT 0.25 x 333 SEK = 83 SEK.
The Swedish customs should not try to collect VAT if the VAT ends up beeing less than 100 SEK. Lets see if this actually holds true or if they somehow use their own kind of math to increase the value of my package.
The Batman.
The attachment Na na na na na na na na na na na na na na na na... BATMAN!.jpg is no longer available
Reply 5354 of 31480, by brostenen
cyclone3d wrote:
And remember, you can always leave the DX2-80 in there even if you need 50Mhz or 66Mhz. […]
That is another way to do it. Regarding led's and button/switch, then I need to get a case first.
After all, it is only on a testbench as of now.
Reply 5355 of 31480, by appiah4
Tried to make an 8GB USB Stick work with my P166MMX Windows 98 install and failed.. All pointers welcome..
Reply 5356 of 31480, by Skyscraper
Try this driver package.
It's only USB 1.1 but my success rate with getting USB storage working in Windows 98 SE is 100% so far when using this package.
The attachment nusb24e.exe is no longer available
Reply 5357 of 31480, by Munx
Got a Socket 754 board (that I thought was dead) to post with the help of this thing.
The attachment P_20170323_210405[1].jpg is no longer available
Never thought this was actually needed when using modern PSUs on older boards 😵
My builds!
The Underdog - The budget K6
Reply 5358 of 31480, by appiah4
Skyscraper wrote:
Try this driver package. […]
nusb24e.exe
Ive tried v3.3 of this but had no luck. It requires uninstalling the usb hub prior to installing the driver but the keyboard mouse I have are usb...
Reply 5359 of 31480, by cyclone3d
You don't actually have to uninstall anything before installing it. I saw that in the instructions and thought... why?
It works if you just run the installer without doing anything first.
YMF7x4 Guide
