Fun fact
First post, by xjas
External Iomega Jaz drives are actually 3.5" internal drives in a fancy housing with an integrated HD50 adapter.
The attachment DSC01667.JPG is no longer available
The attachment DSC01670.JPG is no longer available
The attachment DSC01666.JPG is no longer available
This is useful to know if, like me, you lack the Jaz's 5-pin mini-DIN PSU, but want to use the drive anyway. Open it up and it's a bog standard 50-pin SCSI & MOLEX power cable.
Finally I was able to read my one and only Jaz cart.
The attachment DSC01672.JPG is no longer available
I don't know what makes these tools "asian", but I was happily able to recover this gem:
https://www.dropbox.com/s/666nivjckezqx8c/INTRO.MOV?dl=0
...which as far as I can tell is on Archive.org but not on Youtube or anywhere else on the web. So if you need that one Gold Nugget of Original Content for your Retro-Tech!(tm) channel, here you go. 😜
The attachment sexophone.jpg is no longer available
(^^ This video is only from 1997!)
Reply 1 of 4, by luckybob
This is actually more common than you think. Backpack drives did this, and LS-120 drives too, but they had a different face plate.
Reply 2 of 4, by spiroyster
External hard drives are also a popular incarnation of this kind of behaviour.
Reply 3 of 4, by torindkflt
Also common with external (non-slimline) optical drives. Recently disassembled an external Firewire DVD burner from an old eMac system my brother gave me and pulled a standard IDE drive from it to add to my spare. It's often cheaper for them to just build an adapter and housing for existing models of internal drive than it is to redesign an entire new model of drive solely for external use.
Reply 4 of 4, by xjas
Yeah I get why on external HDDs/CDs/DVDs, especially into the USB/FW era, but was expecting Jaz drives to be different as a single company developed the tech and made the whole thing - drive, enclosure, media, etc. Hell, I didn't even know they made an internal Jaz drive until I looked it up just now - but I guess they actually never made an *external* one. 😜
If you are easily amused & not offended by vulgarity, google iomega "asian tools" (with quotes.) The results (all seven of them) get funnier towards the end.
