First post, by moondog
Hi everyone, im currently building a hyperspin setup. Im stuck on Dos Box as there doesnt seem to be any hyperspin support for it anywhere. Or at least for the android version.
Not sure if anyone here is familiar with hyperspin android, but basically its a front end for all your retro games and uses retroarch cores for emulation.
The is a working Dos Box core for retroarch and people have tested it outside of hyperspin. The problem is that in order to work with hyperspin there has to be a .ini settings file. This is basically a command line that tells the emulator to run the selected game with 1 click.
As there has been some collaboration between retroarch and Dos Box with regard to the core, I was wondering if anyone can help out?
ive attached a .ini file from another console as an example.
many thanks
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
You have to ask hyperspin/retroarch.
They added dosbox on their own. We have nothing to do with it.
Water flows down the stream
Reply 2 of 2, by moondog
Ah ok. Thanks anyway
