Malvineous wrote:Sounds like it needs some server-side code to avoid case sensitivity, like Samba does when sharing a case-sensitive filesystem over CIFS.
I don't like the idea of having a special filesystem just for DOS stuff on the server
Malvineous wrote:What are some of the corner cases that come up when you're only dealing with converting an ASCII character set to upper/lower case?
Malvineous wrote:Like I said above, you do it the way Samba does. First file is FILE.TXT, second is FILE~1.TXT, third is FILE~2.TXT, etc. That problem has already been solved. Heck even DOSBox does it this way, but most people don't even notice because you never have files named like this anyway unless something has gone wrong.
DOSBox is open source, if it bothers you writing the code to handle names like this, just copy it from DOSBox.
Users browsing this forum: No registered users and 7 guests
