First post, by luisile
Hi Vogoners. I am looking for user manual and a bios update for this motherboard. Normal i will find this by searching on google but no luck with this motherboard. i need help from you maybe somebody has original cd at home. Thanks for answer
Little bit of info
Epox EP-8kda3I
AMD socket 754
NForce3 250gb
Agp8x, Sata, Pci
Reply 1 of 4, by darry
According to http://www.supox.cn/pr_old_play.php?type=dw&pr_id=148 ,
latest BIOS is dated 2006-9-22 its filename is da3i6907.bin
This link seems to have it :
https://web-beta.archive.org/web/201603110331 … OS/da3i6907.bin
and this MIGHT be the manual for your board or possibly a similar model :
http://common.ddix.ru/data/download/brands/ep … -8kda3i_v20.pdf
Reply 2 of 4, by luisile
How did you find it? i did not came across this files on my search
THANK YOU!
Reply 3 of 4, by luisile
Bios updated working GOOD!
The manual is for different layout maybe for 8kda3J or + version but nevermind.
THANKS for help!
Reply 4 of 4, by darry
Happy to help . I have been looking for Epox/Ipox BIOSes for a while (I have an Ipox 3ETI23) and one site I found happened to have some info on your board, including BIOS file names . Then it was just a question of plugging the file name into a search engine .
