First post, by keenmaster486
I have a Vibra 16 C card. Right now it's plugged into a 286 motherboard with no hard drive and a single 720K floppy, for testing purposes. I want to initialize the OPL3 chip without having to load any device drivers from the disk, just with a single utility.
Is this possible?
If not, which drivers should I load at the bare minimum to make this card functional?
World's foremost 486 enjoyer.
Reply 1 of 15, by gdjacobs
If it's a soft programmable card but not PnP, you just need DIAGNOSE.
Reply 2 of 15, by keenmaster486
Hmm... Interesting.
So on a 286 I just run DIAGNOSE and it will work?
That doesn't appear to work... I ran DIAGNOSE and it chokes when I tell it that the card is set at address 220. It can't find the card.
Reply 3 of 15, by gdjacobs
It might be PnP in which case you need CTCM (or possibly a workaround).
Reply 4 of 15, by keenmaster486
Oh, just realized I forgot to include the model number in the OP! It's a CT2960. Do we know whether that is a PnP card or not?
Reply 5 of 15, by PhilsComputerLab
Just install it the standard way, and it will tell you.
2 disks, SBBASIC and CTCMBBS.
Run SBBASIC installation, if it asks for CTCM disk, you know it's PnP. If not, then it's not. Pretty easy 😀
Reply 6 of 15, by keenmaster486
Thanks Phil, that's what I'd be doing but unfortunately I don't have that luxury 🙁 . All I have is a single 720K drive. No HDD.
Reply 7 of 15, by PhilsComputerLab
Got another machine to test it out?
Reply 8 of 15, by dr.sbaitso
If i recall correctly, all the SB Vibra 16S and 16C cards are plug and play.
Reply 9 of 15, by gdjacobs
If the Vibra S uses a CT2504 chip, it may not be PnP. The 2960 uses a Vibra C chip so you do require PnP configuration.
Reply 10 of 15, by keenmaster486
I wish 🙁 Currently I'm away from my primary DOS/Win98 machines I'd be using otherwise. I'm just trying to see if I can make it work with this 286 motherboard I found.
OK, that clears things up a little - so assuming it is PnP, then what's the bare minimum with the least memory usage that I would have to load/run to initialize (at the minimum) the OPL3 chip?
Reply 11 of 15, by badmojo
I haven't ever seen a Vibra16C with an OPL3 chip.
Reply 12 of 15, by keenmaster486
Badmojo, I know it's not a real OPL3. I don't care, I just want to initialize it.
Reply 13 of 15, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
CTCM can not run on a 286 (probably compiled for 386+).
Have a look here: Installing PnP Soundblaster in 286/386 system?
The tool by dca2 worked fine on my attempt - a CT4180. It's not a TSR and thus takes no memory.
1+1=10
Reply 14 of 15, by keenmaster486
h-a-l-9000 wrote:
Have a look here: viewtopic.php?t=35282
YES!!!!!
This is EXACTLY what I was looking for. Worked perfectly first try, no questions asked. I now have a fully initialized Sound Blaster with no memory used. Bingo!
Thank you!
Reply 15 of 15, by gdjacobs
It's the onboard CQM core.
