First post, by Errius
Hello, is there a way of seeing how much memory a game takes up while running in DOSBox. I would like to know which games will run on an IBM PC with 64K, 128K, 256K and 512K without having to mess with real hardware.
"AI Requires Proof That You Are Human"
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
decrease the amount of available memory inside dosbox using loadfix to get the amounts available that you want (and set the memsize to 1 and disable umb,ems,xms)
Water flows down the stream
