Reply 16640 of 59750, by chose007
actually working on UNI reduction for all sockets, than can start my evil plans 😁
Reply 16641 of 59750, by agent_x007
Skyscraper wrote:
Using a "Soft FSB tool" to set a FSB of 166+ MHz is of course an option but I'm not sure it's possible to get very far unless using a 200 MHz "start up" FSB.
If the Gallatins dosn't gain much performance from high FSB then perhaps the very cheap 3.2 Ghz (1MB) Gallatins I ordered yesterday could be worth using. They will POST at 24x133 but if their multiplier is unlocked settng the speed to 21*166 in the BIOS for 3500 MHz would probably be somewhat faster than 24 x 146 MHz = 3500 MHz, if they will handle that speed that is.
When it comes to the Gallatin with 4MB cache I know they works reliable in the older Asus PC-DL i875 motherboard as that board has native support for 100/400 MHz FSB CPUs but as it dosn't seem it's possible to force the NCCH-DL to 100 MHz FSB during CPU initialization they will not work at all unless they can handle 30x133 = 4GHz during POST. This is at least what I have gathered from reading forum posts so far but I have to admit that I have not had the time to fully read up on the matter yet.
Scores to beat my friend :
The attachment SuperPI 1M mini.png is no longer available
The attachment SuperPI 32M mini.png is no longer available
The attachment Cinebench 2003.png is no longer available
The attachment Cinebench 11.5.png is no longer available
Good luck 😉
Reply 16642 of 59750, by Skyscraper
agent_x007 wrote:
Scores to beat my friend : […]
Gallatin scores
Good luck 😉
Well I have at least also benched a Gallatin at 4 Ghz! 😉
The attachment gallatin3400_4000_superpi1m.JPG is no longer available
The attachment gallatin3400_4000_x1950pro_3dmark2001.JPG is no longer available
As You can see I had to use alot of voltage but that was no issue as I was using water cooling when benching the Gallatin... After a while the system started crashing and restarting. I changed memory timings and other BIOS settings trying to get the system bench stable again and it was not until many restarts and crashes later I heard a ticking noise from the water block... I had used a Zalman fan controller to make the large overkill pump a bit less noisy but the pump had suddenly decided that the voltage was too low and stopped and this was the reason for the instability, the CPU temp was through the roof! 😁
I found out that the Asus NCCH-DL compatibility issues with the Gallatin Xeon MP seems to have been fixed with the 1.003 BIOS! If the compatibility is not broken again in later BIOS revisions I guess the scores I really will try to beat are member havlis scores with his Gallatin Xeon MP 4M! I kind of like the odds as I happend to buy a couple extra SL79V Xeons just in case I also get a lemon that wont do more than 3.3 GHz! 😈
The extra cache wont be enough to beat a s478/s775 Gallatin @4Ghz in single core benchmarks as 3.6 - 3.7 GHZ seems to be the absolute limit for a really good Gallatin Xeon MP 4M, I think 3.8+ GHz would be needed. One issue I will have is cooling, I own a single Noctua cooler with Socket 604 mounting kit but I modified it to fit on my MSI K8T Master2 FAR and it will probably stay there,.other than the Noctua cooler I have only really really crappy Socket 603/604 coolers. I will have to build my own mounting kit so I can use some decent tower coolers...
To keep us on topic. I bought a few of these today.
Gallatin Xeon 3GHz 4M SL79V
The attachment Xeon 3GHz 4M SL79V.JPG is no longer available
Reply 16643 of 59750, by tikoellner
Finally.
I'm picking up this bastard tomorrow.
I must say that I'm done here. This is true retro stuff. It was my dream to owe one in a perfect shape for such a long time...
I actually can't imagine better Prince of Persia experience than what you get on this kind of machine.
Reply 16644 of 59750, by blurks
IBM XT's are just... mmmh... delicious...
Reply 16645 of 59750, by luckybob
Look at the monitor, it will either be a 5154 or 5153. The former being EGA and INCREDIBLY expensive in working condition.
Reply 16646 of 59750, by tikoellner
Confirmed its EGA 😀
I paid 150usd for the whole set. There is also a set of documents and boxed dos 3.0 included.
Reply 16647 of 59750, by luckybob
If the monitor works, its worth 3x what you paid. AWESOME!!
Reply 16648 of 59750, by tikoellner
Yes, it works. And is in perfect shape. It was bought in the 80s in Sweden by one musican (qute well known in Poland where I live) that really cares about his stuff. I can't wait to see what's inside. Would really craze out if there was some IBM sound card in this XT
Reply 16649 of 59750, by Kreshna Aryaguna Nurzaman
So, was there?
IBM Music card supports MIDI, doesn't it? I imagine musician in the past would use text-based MIDI sequencer with their PC-XT to control MIDI devices. I remember composing MIDI songs with Voyetra Sequencer Plus Pro on a 286. Yes, MIDI sequencer works on such old PC.
Kreshna Aryaguna Nurzaman.
Reply 16650 of 59750, by Cyrix200+
So I went to a local PC store/recycler to pick a a CPU for a friend, I got talking with the owner and walked out with the CPU, and this beauty: Total surprise for me to find it there, and it cost me 20 euro so I'm not complaining 😉
It should be working, he wasn't 100% sure though. Now, to find a Pentium Pro CPU cooler.......
LeZNKvjl.jpg?1
1982 to 2001
Reply 16651 of 59750, by tikoellner
Unfortunately, no IBM feature card was found inside 😀 Just CGA and EGA adapters, I/O controllers, HDD and floppy controller. That's it.
After giving it some proper clean I just plugged my CT-1320A inside.
It's so slow! 😀 Can't actually play Prince of Persia... But Arkanoid works fine.
Reply 16652 of 59750, by dexvx
I bought this guy sitting alone in the bin (for maybe 3 weeks or so) at a local tech surplus store for $6. It installs as a Trident Blade 3D. Most likely T-16 variant (9950). It's 16MB AGP. Gets an awesome 1650 3DMark 2000 on defaults (with a Athlon XP 2000+).
Reply 16653 of 59750, by luckybob
@Cyrix200+
Oh thats nice!
Reply 16654 of 59750, by rein_ein
3$ to my friend goldscrapper and i got:
Asus K7M with missing 6 coils,all other looks good,can't say i came too late but at least i rescued what is left... in search of donor now
Reply 16655 of 59750, by Cyrix200+
I have one in working condition, let me know if you need information! I love Slot A
1982 to 2001
Reply 16656 of 59750, by MCGA
tikoellner wrote:
Finally. […]
Finally.
This is this is the stuff dreams are made of. 😀
Reply 16657 of 59750, by Kreshna Aryaguna Nurzaman
I see. Too bad, it would be very interesting to see how a PC XT runs extrenal MIDI device.
Anyway, it's too slow to play Prince of Persia? I remember the first time I play PoP was on my cousin's PC XT, and it wasn't too slow.
Reply 16658 of 59750, by tikoellner
Actually it could be some XT clone. Those were sometimes faster than 4mhz. There was also IBM XT 286. Maybe that's the reason.
Reply 16659 of 59750, by dexvx
Bought these semi-locally. Had to drive about 100 miles each way. Ran 3DMark on them, flawless. Although the fans seem kind of rattly (not exactly). The fans seemed like they could use lube, but they are fully enclosed ball-bearing fans, so I'll just replace them when they fail.
And their 3DMark scores, looks like AGP vs PCI didn't make a difference for games of that era on this card.
