PSU - bust the myth
Reply 300 of 382, by ODwilly
You should be fine with a 700watter. Any modern 600+ should be able to handle that no problem. For budget supplies Iv been swearing by the EVGA units. They range from good to very good and tend to go on sale for low prices.
Reply 301 of 382, by gdjacobs
Anandtech's rig drew about 480W with an i7-920 running furmark. I think you'd want to look at the 550W to 600W range, minimum. EVGA would probably be a good option, as they seem to have very good performance, construction, and are highly price competitive.
http://www.jonnyguru.com/modules.php?name=NDR … =Story&reid=380
Reply 302 of 382, by TELVM
The GTX 480 alone draws about 320W @ full steam.
About whole system draw:
http://www.tomshardware.com/reviews/geforce-g … 80,2585-15.html
^ That's grinding Furmark on a X58 i7-980X system, i.e. worst case scenario on a rig hungrier than yours.
Thus any decent 550W PSU will provide ample of juice for your rig.
Some suggestions (not too cheap, not too expensive, all DC-DC & bronze or gold):
Antec VPF550
Bitfenix Whisper M 550
Corsair CX550M
EVGA Supernova G2 550W
Seasonic G 550
Let the air flow!
Reply 303 of 382, by Kadath
Thanks guys, I really appreciate your help - thanks for the useful info, I'll get one of these 550-600w models then.
First comes smiles,
then lies.
Last is gunfire.
Reply 304 of 382, by PhilsComputerLab
Any thoughts on this Pentium 4 era PSU?
I got give two boxes, one with parts inside, the other one is a BIN case! Both have the same PSU. Decent 5V Rail, so should be good for an Athlon XP build.
Reply 305 of 382, by appiah4
PhilsComputerLab wrote:
Any thoughts on this Pentium 4 era PSU? […]
I have a 300W model of the same PSU for my Celeron 1300 machine and I'm hunting down a 350-400W for an Athlon XP + 9800PRO machine; for the era you can't go wrong with Forton-Source FSP PSUs, they were THE top dog and the golden standard shitty PSUs got compared with in the AthlonXP era.
They are not quiet though. Don't believe the Noise Killer lie.
While I'm here I may as well ask this: How much power would a Pentium MMX + PCI Graphics Card + Voodoo 2 12MB draw? I am using this setup with a no name (well, it's branded Channel Well Technology but I guess that's another name for Useless Shit Haha) 230W PSU that came out of a (believe it or not) Celeron 1700 case, because to be frank as bad as it is (it's feather light) it probably isn't worse than anything we used back in 1995.. Am I asking for trouble here?
Reply 306 of 382, by PhilsComputerLab
Awesome! I will take a photo of the inside once I get closer to using it.
Reply 307 of 382, by gdjacobs
Sweet! If it looks good, it goes on my thread!
Reply 308 of 382, by TELVM
Any thoughts on this Pentium 4 era PSU? ... […]
Found some pics of its guts here.
Old style half-bridge with BJTs, passive PFC and group regulation. All or most caps are Teapo (could be much worse). Looks decently built though the heatsinks are a bit skinny.
If the caps and fan are OK should be fine to power retrocomps.
Probably not even 100W DC.
Let the air flow!
Reply 309 of 382, by PhilsComputerLab
Thank you!
Reply 310 of 382, by gdjacobs
I can't see if the input filter includes a MOV or TVS diode which is important in this case due to a lack of APFC.
Reply 311 of 382, by TELVM
From this pic of a 400PNR there are probably two small MOVs (yellow thing drapped in black heatshrink) between the bulk caps:
http://tokes.ru/bloki-pitaniya/38-remont-fsp-atx-400pnr
^ One DM311 PWM controller for +5VSB can also be seen, so no 2-transistor sweat.
Let the air flow!
Reply 312 of 382, by gdjacobs
I'm not entirely sure what revisions were made with the PNR as the rail capacities were substantially different from the PN. I hope the input filtering is complete, as it's always good to have more options for +5V heavy loads.
Reply 313 of 382, by elod
I remember the caps blowing on the 5vsb line in these supplies right after the 2 year warranty. They are safe though.
Reply 314 of 382, by gdjacobs
Yes, using a PWM controller makes the 5VSB design much safer in the face of failing caps.
Reply 315 of 382, by TELVM
PWM chip is safer than 2-transistor, but FUBAR crappy caps will ruin the day anyways.
The Antec SL300 in this post mortem had a UC3844B PWM controller on +5VSB, and yet:
"... With only the old 680µF Fuhjyyu caps, the 5VSB output settles around 5V, is horribly noisy and shows horrible power-up transients peaking at up to 16V (clearly no good for capacitors rated only for 10V) ..."
"... When all of the capacitors on a flyback power supply's outputs have failed, there is little left standing in the way of flyback operation generating high voltage spikes and destroying components ..."
elod wrote:
I remember the caps blowing on the 5vsb line in these supplies right after the 2 year warranty ...
^ That's the kinf of hard earned wisdom that screams RECAP!!!.
For retrocomps with dubious caps onboard the PSU (aged or crappy) that are used only occasionally, I'd switch the PSU off whenever the comp is turned off. +5VSB circuit is always live whenever ATX PSU is plugged to wall and switched on (regardless of comp turned off), so +5VSB caps are always receiving juice, ripple and heat (with the added 'bonus' that PSU fan is stopped and moving no air). Switching off PSU whenever comp is turned off spares them a ton of stress.
If we also unplug PSU from wall whenever comp is turned off, we'll get full protection from storms (barring a bullseye direct lightning strike that sets our home on fire).
Let the air flow!
Reply 316 of 382, by gdjacobs
Fuhjyyu has ruined more days than the weather.
Reply 317 of 382, by TELVM
Couple of examples to illustrate the point.
Barely passable cheap PSU with Junk Fu & Su'scam crap all around the secondary, with one single exception, this Chemicon KY:
It's the first filtering cap downstream from the +5VSB trafo. Even on this cheap PSU the engineers wisely resisted the temptation of penny-pinching on this particular cap.
Good PSU with Seasonic guts:
That humungous grossly oversized 4700uF is the largest cap in the whole secondary, it's almost as large as the +5VSB trafo. Why? The larger the can, the higher the ripple tolerance and the heat dissipation of the capacitor == the longer the life == the lesser the chance of a ran amok +5VSB barbecuing the southbridge and murdering the mobo.
Let the air flow!
Reply 318 of 382, by gdjacobs
Simply because of the constant load, yes?
Reply 319 of 382, by PcBytes
PCBONEZ wrote:
All the Antec Smart-(whatever) and True-(whatever) models were loaded with Fuhjyyu. Others were too. Just don't recall them. . T […]
TELVM wrote:
HOWEVER be advised that the Phantoms (like other Antecs of that time) were stuffed full of Fuhjyyu crapacitors, amongst the worst and less reliable junk ever laid inside a PSU, which after more than a decade shouldn't be relied upon (to put it softly).
Antec Phantom 500 ruined by Fuhjyyu crapacitors
These are old pics I took 5-10 years ago.
I saw some of these. Still can't understand why people chose to throw them away instead of recapping them. Honestly,I recapped FSP and other units with caps in harder spots than that,and with bigger diameters when I didn't have the same diameter of caps I had to replace.
