First post, by zerker
So I found out the DOS MODE command allows you to theoretically redirect a parallel port to a serial port. This is potentially great, as I can just capture the serial output on another machine via null modem and save formatted print output to disk.
Trouble is, it doesn't seem to work. I initially run the command and the output looks promising:
> mode lpt1=com1
LPT1: rerouted to COM1:
But as soon as I check the general mode status again, it says it isn't redirected after all.
> mode
Status for device LPT1:
LPT1: not rerouted
Retry=NONE
Code page operation not supported on this device
Status for device LPT2:
LPT2: not rerouted
Status for device LPT3:
LPT3: not rerouted
Status for device CON:
Status for device COM1:
Retry=NONE
If I try to print via MS DOS Edit, or manually redirect a command output to LPT1, it fails just as before. Redirecting a file to COM1, or using a program with serial printing (MS DOS Help) works as usual. I do, of course, already have the mode configured properly for COM1 itself.
I'm running official MS-DOS 6.0. Any thoughts or suggestions? Anyone else tried this sort of thing?
Reply 1 of 5, by Jo22
Hi, running DOSV 6.20 here and it works fine so far. ^^
    25.02 KiB
    28.15 KiB
Reply 3 of 5, by Jo22
Hi, did you try mode lpt1:=com1: (with colons), too ?
Reply 4 of 5, by zerker
I just tried it in a VM, with the same command I originally used, and it works there. Next step is to check if my serial port settings are causing the problem. Maybe 19200 baud is too fast to permit redirection?
EDIT: And did a bit more testing on my real machine. Didn't have any more luck than before with 9600 baud, or with colons in the ports. I noticed one difference from the VM, it printed the message:
"Resident portion of MODE loaded"
which is not printed on my real machine at all.
I've tried with a bare-bones configuration to essentially match the VM's fresh install, but no change with that either. Finally, I tried disabling the real parallel port in the BIOS (since nothing is connected), but that made no difference.
Reply 5 of 5, by Jo22
Sorry to hear. 🙁 My copy of DOS holds MODE in memory. It consumes about 480 bytes of memory.
Maybe I'll check again as soon as I have access to a real DOS machine again.
    30.9 KiB
