First post, by okipouros
Sometimes i get "illegal read xxxxxxxx" where xxxxxxx is some hex memory adress, and sometimes "sdl lock failed"
Reply 1 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
What application/game do you run?
Mirek
Reply 2 of 4, by okipouros
privateer 2
i i have an xp2400, and set cpu cycles to 22000, and cpu usage was around 95% max, if that is helpfull
Reply 3 of 4, by Moridin
Hey, i'm having a problem installing Privateer 2 just wondering if anyone knows a possible solution. Alright the problem i'm having is when installing once i've selected a music card and installer goes off to detect it (whether i let it autodetect or choose the ports manually) the installer freezes and i get the error "illegal read from XXXXXXXX" (where the X's are a hex memory address) i've tried using Dos-box 0.61 and 0.63 to see if it was just a problem with one or the other but both have the same problem
Now i've gone through all the topics trying to see if anyone else has had this problem and i only found one other person who has but no-one had posted an answer as yet so i'm hoping i'll have more luck
Thanks
P.S - I'm running a P4 3.2GHz, 1GB RAM (if you need any more info just tell me what you need to know)
Reply 4 of 4, by eL_PuSHeR
Moridin - I deleted your previous post (almost identical) and merged related posts. Please, avoid crossposting in the future.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
