First post, by BLockOUT
Hey there, today i had some time free to test 2 boards, PCCHIPS m919 and also PCCHIPS m912
using this CPU i read from a website that its an AMD Enhaced DX2 66
http://www.cpu-collection.de/?l0=co&l1=AMD&l2=486%20DX
First the M919 motherboard, it was not booting, i changed the isa video card two times, changed the memory, black screen not booting, even used the botom last isa slot and nothing, Then i inserted a PCI graphics card and booted for the first time. But because i got no IDE drive it gave the usual DOS error after booting and it said. 100MHZ, i dont know why!
I followed this manual, used the AMD enhaced jumper settings: http://th2chips.freeservers.com/m919/jumper/index.html
but i left JP6 OFF because i think that is for other cpus that i dont have.
i don´t know why DOS boots and shows 100MHZ, as soon as i saw that i turned off the pc
THEN i used the other motherboard, the Pcchips 912, inserted the same AMD CPU dx2 66, and it did not boot with the isa graphics card black screen, then i used one of the larger longer slots at the bottom of the motherboard and it booted fine finally, but again , it is also showing 100mhz and i don´t understand
this is the setup that i used to configure the motherboard
I currently don´t know why it is saying 100mhz at this point.
Can anyone help?
