Similarly, I wonder what would append if one would mix two PCM (not dolby digital) output signal. I am not very familiar with this protocol but I assume some sync is sent time to time to inform the receiver of the bit depth and rate. So let say they are the same.
On my setup I have a sblive and awe32 both connected to different digital rca input of an onkyo tx-8140 receiver. Now, what would append if I cross the line and put both cards output with a Y cable on one input of the receiver?
- No sound or white noise.
- Perfect and crystal clear mixing of two sources
- Total flaming obliteration of my precious hardware
