First post, by Arctic
01. Dual Pentium 3 1.0EB GHz / 2048MB SD133 CL2 / Epox EP-D3VA / TEST CARD Geforce FX 5200 128MB / or any suggestions?
02. Pentium III-S 1400MHz (Tualatin-512k) SL6BY / 512MB SD133 2-3-2-8 / Asus TUSL2-C / Voodoo 5 5500 64MB AGP 2x
03. Mobile Pentium II-PE 366MHz (Dixon) / 224MB SD66 CL2 2-2-2 / ThinkPad 600E (440BX) / NeoMagic MagicMedia256AV (Thinkpad 600E)
I already have Windows 98SE running on most of the others, so I don't really need another one. Any suggestions?
Should I install Windows 95 on system 03 since it has no 3D accelerator anyway?
What about OS/2?
Reply 1 of 9, by Jorpho
I always say: decide what you're going to do with these systems, and choose the OS accordingly. If they're just going to go in a corner and collect dust, then it doesn't really matter what you choose. I guess I'm not much fun. 😜
If you have some burning need for the Windows 95 experience, then go ahead and install it, but I can't see any particular advantage that would give you on a system with 224 MB of RAM.
If you install OS/2 then it is very likely you will spend half an hour poking at it and then never use it again.
Reply 2 of 9, by luisile
Best answer what you can get...
Reply 3 of 9, by Arctic
I am not a beginner in this area. So creating problems and solving them is part of the hobby for me.
Installing an OS that I have never used before will most likely create problems. Solving them is fun! 😁
I am not trying to build a machine with a purpose per sé...
So no recommendations besides Windows 98 and Windows XP?
I was hoping to hear something along the lines of:
"If you have an xyz, you should totally install OS blah.
Then you could check out yaddeeyah and such."
Reply 4 of 9, by xjas
That dual P3 would probably make a fantastic Haiku machine. 😁
Reply 5 of 9, by Arctic
Yay! Thank you for your response!
I will check it out 😀
Reply 6 of 9, by Jorpho
So, you're just looking for random operating systems that will cause problems?
Plan 9
Solaris
BeOS
NetBSD
OS/2
Syllable
Breadbox Ensemble
ReactOS
Darwin x86
Android x86 / RemixOS
QNX
EDIT: MenuetOS
I don't think it matters what you try to install them on, since using non-recommended hardware will cause more problems.
Reply 7 of 9, by jade_angel
Of those, NetBSD should be a pretty smooth experience, actually. The others? Various levels of sticky. Though I do rather like OS/2 - pure crazy sentimentalism. It's what I had on my first "real computer".
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 8 of 9, by RetroGamingNovice
At 224MB? You can get away with minimal Debian Stable if considering any Linux distros.
Bare minimum required RAM for Debian is 128MB with just the console.
With a desktop, you need 256MB.
PC hardware: Ryzen 5 4500, 32GB RAM, 1TB SN 570 /500GB 970 EVO Plus/2TB 970 EVO Plus/1TB 870 EVO,, RX 6600 GPU, Arch Linux/Win10 dual-boot
