Reply 5700 of 30137, by bjwil1991
- l33t
wrote:wrote:wrote:Are you getting any mechanical indication of the drive attempting to read the disk? If you get an instant error returned then it's most likely a driver or configuration issue. If you hear it trying to focus lock clean the lens and lube the rails.
It is attempting to read the disk when the laser is about 1cm away from the spindle, but the drive spins up, then down, and the head does move. I tried cleaning the lens, and the rails are a PITA to get to. And what should I use to lubricate the rails?
Depending on the type lithium grease or sewing machine oil, or in rare cases they are meant to be unlubricated and you just need to clean off the dust. That's usually very high end audio transports though. If the old stuff looks thick and paste like then use lithium grease, if not then use a small amount of sewing machine oil. Using a wooden toothpick to apply it helps make sure you dont use too much.
Also when cleaning the lens, generous amounts of high percentage rubbing alcohol work best because you can dissolve the dirt in it and it gets absorbed by the q-tip and the remainder evaporates away from the lens instead of having to wipe it dry and leave smudges.
Welp, I looked at the lens glass, and there's a white spot on there and I can't get it out. Would it be possible to replace the lens from another laptop DVD/CD combo drive? And I also can't remove the HDD as the door is stuck, as well as the eject mechanism.
