Reply 17001 of 52977, by keropi
finally got that Olivetti 286 EGA setup, what I wanted from the set was the color EGA monitor 🤣
I had to replace a single filtering capacitor on the PSU (X2 one) but other than that it's great. The monitor is a Hyundai HCM-1420 with great build quality and nippon-chemicon eletrolytic caps - these I won't touch 😎
Reply 17002 of 52977, by SaxxonPike
Received the S3 TrioV2/DX. Seems to be a really fast and compatible card! I got the card plus manuals and driver disc. The card's condition was immaculate.
699.48 KiB
408.64 KiB
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 17003 of 52977, by Batyra
Just got my boxed SW20-PC and my Yamahas soundcards family is one step closer to be complete.
Was DB51 and DB60 boxed? I Know that DB51 was a part of some external midi modules like Korg but DB60 was a stand-alone card in box?
I know that DB50 has a Nec clone. Did DB60 had Nec clone too?
    362.54 KiB
    Yamaha SW20-PC, DB50GX, SW60XG, SW1000XG
    259.52 KiB
    Yamaha SW20-PC
Reply 17004 of 52977, by hard1k
DB50XG - had no NEC clone, was packaged in at least 2 different boxes (the one you have and another one, more "horizontal")
DB51XG - had no NEC clone, haven't been spotted boxed in the wild, was used in Korg NX5R modules as a built-in option
DB60XG - had NEC XR385 clone used in Japanese PC-98 systems, neither one have been spotted boxed, the original (Yamaha-branded) is used on the Audiotrix Mediatrix 3D-XG card.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 17005 of 52977, by keropi
nice stuff!!!!
I wonder, how much a boxed SW20-PC goes for nowdays?
Reply 17006 of 52977, by Batyra
Thanks for info... have to slowly start looking now for sw60 or its clone then.
keropi wrote:
nice stuff!!!!
I allready had SW20 now a box, manual etc are gift from a friend.
Reply 17007 of 52977, by SaxxonPike
Very nice find!
Sound Blaster
Aztech
OPL3-SA
Reply 17009 of 52977, by dexvx
Snagged this Hercules Prophet II Ultra (GF2 Ultra) on eBay for cheap, as it was mislabeled. Unfortunately, the fan barely spins (I unplugged it, trying to find a Hercules replacement seems really hard). I had a 60mm fan blowing on it, but it still needs to be heavily underclocked for 3D to work.
Reply 17010 of 52977, by Deksor
Unscrew the fan, tear the sticker on the back and then you should be in front to the fan's axis. Add just a little bit of oil or grease to make it work again. Then put back the sticker and re screw it and if you're lucky, the fan should work again
Reply 17011 of 52977, by deleted_Rc
dexvx wrote:
Snagged this Hercules Prophet II Ultra (GF2 Ultra) on eBay for cheap, as it was mislabeled. Unfortunately, the fan barely spins […]
Aliexpress has replacement fans cheap or otherwise ebay for a original. Don't throw the old one you likely need to change the connector as those are minI 2 pins.
Reply 17012 of 52977, by Cyrix200+
I picked up this beast yesterday. The case weighs a tonne! Thick steel everywhere. Nice quality.
Inside: An Abit VP6 with two Pentium III 1GHZ CPU's
Some cards. Jaton 3DForce B-32Plus (lovely name 😉) AGP (I guess it's an TNT2 M64). 3Com NIC. Terratec DMX Xfire 1024 (Crystal CA4624 chip).
d18vlS0l.jpg?1
There is also a Kenwood TrueX 72x CD-ROm drive. I haven't tested it, but that probably doesn't work anymore.
The board would not post with a video card in the AGP or top PCI slot, upon further inspection I found:
So I've got some work to do if I want to use this board 😀
1982 to 2001
Reply 17013 of 52977, by MMaximus
Nice!
Do you have analog controls on the side or at the back maybe? Looks like there's still room to increase the picture size 😀
Hard Disk Sounds
Reply 17014 of 52977, by meljor
Cyrix200+ wrote:
I picked up this beast yesterday. The case weighs a tonne! Thick steel everywhere. Nice quality. […]
d18vlS0l.jpg?1
Nice! Now i finally know what board is inside 😎
I asked the seller if he could check the brand/type of the motherboard but he never answered, i wondered if it would be a tualatin capable board..
Still a nice setup and hopefully you can fix it.
Reply 17015 of 52977, by keropi
MMaximus wrote:
Nice!
yes, there are analog size/centering controls at the back of the monitor 😊 , didn't mess with them yet
Reply 17016 of 52977, by cj_reha
<snip>
I've always wanted one of those 72x or higher Kenwood drives. 😲 They're really hard to track down, yours is the first I've seen in anything past some early 2000s hardware reviews.
Reply 17017 of 52977, by cyclone3d
cj_reha wrote:
<snip>
I had one of those Kenwood drives back in the day.. when they were new. It was an absolute horrible piece of trash.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 17018 of 52977, by The Serpent Rider
That's exactly same cooler as for any Kyro card. You can find replacement easily.
Reply 17019 of 52977, by gdjacobs
d18vlS0l.jpg?1
That looks like it might have a Lite-On LTD163. That's a far better drive than the Kenwood (although a little noisier than some others).
