Retro Rig Photo Thread
Reply 1120 of 3055, by Murugan
My Commodore 486DX-33 DOS 6.22 rig with:
* Tseng ET4000AX
* Audician 32 Plus soundcard
* 8MB RAM
* Original Commodore keyboard 😀
* HD size is on the picture
* Original 1930 monitor but threw it away because I think there was some problem with the VGA cable 😠
Nothing fancy but it does the job...
My MMX-233 with:
* S3 Virge 86C325 Fastware 2MB (hoping to upgrade it to 4MB if I can find the chips pretty cheap)
* Creative Voodoo2 12MB
* HD of course but forgot the size
* 64MB RAM
* AWE32 PnP (on the picture it's still with an AWE64 in it)
* Win95B
Reply 1121 of 3055, by AzzKickr
Sweeeet !
Heresy grows from idleness ...
Reply 1122 of 3055, by maverick85
ASRock 98
Win98SE Desktop
ASRock
Intel Core 2 Duo E8400 3.0GHz
1 x 512MB 667 MHz DDR2
Soundblaster SB0100 + Altec Lansing ADA885
ATi Radeon X800XT 256MB GDDR3
1 x SATA 120GB HDD
1 x SATA DVD-RW
Reply 1123 of 3055, by SpaceCowboy87
Just finished putting this together today. Had an old 775 board laying around with ram and a Pentium D. All I needed was an atx case which I found yesterday on the curb in the rain. I cleaned all the grime off 😵 took apart the case, washed it and dried it overnight. Today I started fitting everything. I recycled a psu from another case and the harddisk from a broken laptop into this build. Gonna load XP on it and run MAME. Im calling it Optimus Grime 🤣
Reply 1124 of 3055, by Private_Ops
Looks good. Specs?
I'm picky though and those missing bay covers would drive me nuts. 🤣
Reply 1125 of 3055, by SpaceCowboy87
Pentium D @ 3.0ghz
Asus P5ND2-SLI motherboard
2GB Kingston DDR2 SDRAM
120GB WD Scorpio HDD
Philips DVD ROM Drive
Bestec 300W PSU
Unknown generic Atx case
Those empty bays bother me too 🤣 I'd like to fill that gap with a 120 fan somehow.
Reply 1126 of 3055, by Pasi123
SPECS
Manufacturer: WINGS
CPU: Intel Celeron 333MHz
Motherboard: Diamond Micronics C400
RAM: 384MB SDRAM
Graphics: Diamond Viper V550 (Riva TNT)
Sound: Sound Blaster
Hard Drive: 6gb and 8gb
OS: Windows ME and Xubuntu 9.04
The attachment SDC10653.JPG is no longer available
The attachment Kuva004.jpg is no longer available
The attachment Kuva003.jpg is no longer available
X5670 @ 4.4GHz|P6X58D-E|24GB DDR3|GTX 960|750 EVO 250GB|4TB, 2x2Tb HDDs|Define R5|Win7
P4 HT 3.0GHz|GA-8SGXLFS|2GB DDR1|9800 Pro|2x 40GB Seagate|WinXP
Celeron 333MHz|Diamond Micronics C400|384MB RAM|Diamond Viper V550|6GB HDD|WinME
Reply 1127 of 3055, by deleted_Rc
Finished up something fun to play with for now 😎
Barton 3200+ & Thermaltake Volcano 12 cooler (modded with a 120 mm)
Asus A7N8X Deluxe (currently with broken ram port)
Asus A9800 XT
2 GB pc3200 Dual channel 3-3-3-8
Hiper R 580W Modular PSU (fully recapped)
DVD-rom
DVD-RW
FDD
Chieftec Dragon
Reply 1128 of 3055, by loktar
Super Socket 7 build
  • AMD K6-2+ 550
  • voodoo 3 agp (cpu bottle necks it just a tad 🤣)
  • 128mb pc100 ram
  • Turtle Beach Montego.
  • Mobo is a p5f93u with Ali 5 chipset.
  • HDD 32gb miniSD card with ide adapter.
The case came without any bay covers, switch, or turbo display so I got all of those separately and peaced the case together turned out nice imo. Been playing Unreal Tournament on it to test things out, Half life, Quake 3, Theif, and some coop Diablo 2 (glide of course) with my son. Just got another ss7 mobo in the mail today, and one more on the way to get 2 more up and running, mostly want to test comparisons between via, ali, and sis chipsets.
Reply 1129 of 3055, by Pasi123
SPECS
CPU: Intel Pentium 4 HT 3.0GHz Prescott (overheating because shitty cooler from celeron, it's really hard to find a cooler for S478)
Motherboard: Gigabyte GA-8SGXL
RAM: 2gb RAM
Graphics: Ati Radeon 9800 Pro 256mb (doesn't work...)
Hard Drive: 2x Seagate 40gb
OS: Windows XP Professional
The attachment 2017-05-21-110.jpg is no longer available
The attachment 2017-05-21-115.jpg is no longer available
Reply 1130 of 3055, by PcBytes
Pasi123 wrote:
SPECS
Motherboard: Gigabyte GA-8SGXL]
You could try finding a 2.8GHz Northwood and work your way from there.
Also,watch out as you have 2 bulging caps.
Reply 1131 of 3055, by HPI
del...
Reply 1132 of 3055, by oeuvre
Here is the Dell Dimension XPS T600 I picked up on craigslist yestterday, 1 of 4 desktops for $30 total. The others were broken Dell Dimension 2400 which I gutted, a Dimension 8200 which I am installing XP on, and an AMD Sempron 3000+ that needs some work. But this XPS T600 was never opened until I got my hands on it. Cleaned it inside and out and it looks great.
Pentium III 600MHz, 512MB RAM, DVD-ROM + CD/RW drives, 3.5" floppy drive, IOMEGA Zip Drive, 13GB IBM 7200RPM HD, Windows 98SE, 3DFX VooDoo3 3000 16MB AGP, Turtle Beach Montego II A3D AU8830 PCI sound card, PCI ethernet, PCI 56K modem, ISA slot. Runs perfectly. Came with a Dell Quietkey keyboard but not the coveted one, just a meh rubber dome version.
Here are the pictures http://imgur.com/a/sQdUh
Reply 1133 of 3055, by gdjacobs
Worth it just for the Montego II, but that's also a very nice Win98 machine.
Reply 1134 of 3055, by conenubi701
I've been thinking of getting an ATX Mobo like the P4C Deluxe or an Abit IC7 so I can overvolt and attempt to push the clocks a bit higher. Right now this machine is only playing Phantasy Star Online: Blue Burst and Jetfighter III
Pentium 4 3.4Ghz Extreme Edition @ 3.74GHz SL7CH
Asus P4P800-VM FSB @ 880.6 MHz
3GB DDR RAM @ 436MHz
1GB HIS Radeon HD 4670 AGP
R7 2700x/ROG Crosshair VII/32GB DDR4 3200MHz/ROG Strix Vega 64
i7 4790k@4.85GHz/ROG Maximus Gene VII/32GB DDR3 2426MHz/R9 FuryX
Retro
P4 3.4Ghz Extreme Edition@3.74GHz/ Asus P4P800-VM FSB@880.6MHz / 3GB DDR RAM@436MHz / 1GB HIS Radeon HD 4670 AGP
Reply 1135 of 3055, by KCompRoom2000
Build #1 - Socket 7
CPU: Intel Pentium MMX @ 233 MHz (512KB L2 Cache, 3.5x Multiplier, 66 MHz Bus)
RAM: 64MB PC-66 SDRAM
Mobo: Soltek SL-54U5 Baby-AT/ATX Hybrid (BIOS dated June 1999)
Drives: Panasonic 1.44MB 3.5-inch Floppy Drive, 8.4GB Quantum Fireball IDE Hard Drive, NEC 36x IDE CD-ROM Drive
GPU: Diamond Stealth 3D 2000 (S3 Virge 86c325) PCI Video Card w/ 2MB of RAM
NIC: Realtek RTL8139 PCI Network Card
Sound: Sound Blaster 16 WavEffects CT4170 ISA Sound Card
PSU: Sunshine ATX-235NS-1 300W ATX Power Supply
Runs MS-DOS 6.22 with WFW 3.11 & Windows NT Workstation 3.51
The attachment P233 Rig Front.jpg is no longer available
The attachment P233 Rig Inside.jpg is no longer available
The attachment P233 Rig Back.jpg is no longer available
Reply 1136 of 3055, by Batyra
My current build is:
Motherboard: Gigabyte GA-586ATX
RAM: 2x 64MB Simm 72 pin (total 128MB)
Processor: Penitum mmx 233
Graphics: Tseng ET6000 4MB
Accelerator: 2x Voodoo2 12mb Gainward Dragon SLI
Sound: 1. AWE 32 CT2760 + 2x16 ram + Roland SCB-55
Sound: 2. Yamaha SW60
Sound: 3. Gravis Ultrasound ACE 1.1
System: DOS / Windows95
Currently I'm working on using last free ISA slot for Ensoniq Soundscape Elite... so far i manager to make it work together with AWE and Yamaha... GUS ACE still makes a problem... - Any advice?
Reply 1137 of 3055, by Baoran
The attachment 20170531_175749.jpg is no longer available
Reply 1138 of 3055, by oeuvre
Baoran wrote:
Reply 1139 of 3055, by Batyra
And my second build:
Motherboard: Gigabyte GA-5AX 4.1
CPU: AMD K6-2+ 570
RAM: 128mb 133mhz cl2
Graphics: GF256 DDR
System: Windows98SE
Sound 1: Yamaha SW1000GX
Sound 2: AWE64 Gold CT 4540 + SimmConn
Both cards working good without conflict.. now I'll try to add more like Diamond MX300 - it has wavetable....
