First post, by BastlerMike
192.42 KiB
550.22 KiB
Asus VL/I-486SV2GX4 V2.1 / 512 kB Cache
Am5x86-P75
64 MB
Miro 20TD live ET4000/W32p with ET4000/V33 video accelerator and TV tuner
3Com 3C515-TX 100 MBit NIC
Sidejr.pro jumperless Multi-I/O Card
Soundblaster 32 CT3600
Western Digital 6,4 GB HD
Nakamichi 4x speed 4-disc changer
Reply 1 of 5, by chinny22
Well that's different!
I thought were talking about the way 486's were sold with a sound card and CD-ROM had multimedia on the sales literature back in the 90's
Not something that actually had a bit of credibility. with tuners and cd changers.
What do you actually use it for though? isn't it still a bit to slow to take advantage of the above?
Reply 2 of 5, by BastlerMike
Well, you can watch TV and record TV-shows in 320x240. This works fairly good. Sure, the image quality is not comparable with today´s standards, but i guess it was okay back then on a 14 inch monitor. And with a CD changer you can put more on your favourite music playlist than with a single drive.
So this is maybe a little bit more multimedia than the usual "sound card and CD-ROM" thing, but totally realistic for a 1995 system.
Reply 3 of 5, by TheMobRules
Nice! That case looks really clean! 486 + TV Tuner is really interesting!
By the way, how hot does the 5x86 get with passive cooling? I thought a fan was kind of necessary for those...
Reply 4 of 5, by BastlerMike
Depends on the size of the cooler. I use an Intel boxed cooler intended for S370 celerons i guess. It would be better with the fins oriented vertically, but sufficient cooling is provided anyway
Reply 5 of 5, by Anonymous Coward
The case looks nice, but that is probably the best that can be said about it. It used to be my go to case during the PII era, as I could get them for $35 brand new.
