Reply 20 of 31, by Asomodai
wrote:I was using 7900 GX2 (7950 GX2 "prototype", it uses the same drivers as later model). My card was blocking both IDE ports :( […]
My card was blocking both IDE ports 🙁There is a chance, that shorter card will siply sit on top of the already plugged in IDE connector, while still being secured on PCI-e slot.
I was able to do this on second IDE port with my card (one closest to the edge on PCB).
Ahh should be ok then. Mine is 4cm shorter according to official specs!
