Reply 17220 of 57671, by einr
Tetrium wrote:
Is that floppy drive a 2.88 one? The print on the eject button is too small to read 😜
Naw, just a garden variety 1.44M.
TheAbandonwareGuy wrote:
Those symptoms would be consistent with a dead Hard Drive. My guess is it was dropped while running causing a head crash. Shutting the lid too hard can do it as well (I've done that once myself).
Well... I tried switching out the harddrive for a CF-IDE adapter I had laying around and it still doesn't work. Same symptoms. '
If I run the setup program on the reference disk, it does show hard drive as "installed" but FDISK and FORMAT won't find the drive and it's impossible to boot from it.
What's more, the diagnostics on the reference disk wont find and test the hard drive, but the rest of the tests all pass except for the hard drive LED. It doesn't turn on/off like it should. This leads me to believe that maybe something is up with the ribbon cable going to the drive..? Or some kind of controller issue? The drive does get power, at least intermittently, because before I switched the mechanical drive out I could hear it seek test at boot sometimes.
Any ideas, anyone? These are obscure machines, hard to find much troubleshooting info.
Reply 17221 of 57671, by appiah4
Haven't bought it yet, but I'm on the edge of clicking on Confirm.. Is a Sound Blaster 32 (Not AWE32, the 32 model without the 512K onboard ram and mixer options) worth $32 shipped?
Reply 17222 of 57671, by cyclone3d
Where are you located. I am guessing it is model CT3600?
If in the USA, you should be able to get one for about $20 shipped.
http://www.ebay.com/sch/i.html?_odkw=ct3600+- … +-tips&_sacat=0
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 17223 of 57671, by appiah4
cyclone3d wrote:
Where are you located. I am guessing it is model CT3600? […]
Im in Europe, it's shipping from the US, and yes it's a CT3600.
Reply 17224 of 57671, by cyclone3d
Ok, yeah, that is a decent deal when shipping from the US. No dice on finding one more local I guess?
YMF7x4 Guide
Reply 17225 of 57671, by appiah4
Been looking for an AWE32 or Pro 2.0 for a while now, no luck - just a lot of SB16 clones, Audio PCIs, PCI 128s and Live cards hereabouts.. I'm having second thoughts though, as I already have an AWE64 Value. The only reason I want an AWE32 is so that I can use SIMM RAM and load Soundfonts for General MIDI (I'm not happy with AWE64's default GM at all, but finding a SIMMCON for it seems impossible..) CT3600 has the hanging note bug though, so.. 🙁
Reply 17226 of 57671, by cyclone3d
Maybe a CT3670 then. It is basically an AWE64 with simm slots. You can even flash it with the AWE64 firmware to disable the IDE port if you want.
YMF7x4 Guide
Reply 17227 of 57671, by probnot
Picked these up from the local craiglist-equivalent. The guy was selling them as a package with a generic LCD and HP Athlon64 system, but was willing to sell them separately 😀
These will be a welcome upgrade to my cheesy little built-in speakers that fit in a 5.25 bay!
Reply 17228 of 57671, by nforce4max
Nice vintage TV and Radio you got there. 😉
Reply 17229 of 57671, by badmojo
Those are cool! How do they sound? Gotta be better than 5.25" bay speakers I guess.
Reply 17230 of 57671, by krivulak
I have those with other brand but I think it doesn't matter. They sounds awesome, way better then my modern Genius speakers I am using right now on my main rig but I can't upcycle them because they are too big for my teeny tiny desk 😁
Reply 17231 of 57671, by LHN91
Those speakers are great - I've had a set for years and the recycler I go to has a couple sets available right now. They've got RCA jacks for all the connections so they're super versatile and they go plenty loud.
Reply 17232 of 57671, by Tetrium
Got another cheap system from the thrift stores. €15 and it was another gamble. The system was some desktop but with a standard ATX formfactor motherboard. Motherboard turned out to be LGA775 supporting most Conroes. After I got home, it had a single stick of 2GB DDR2-800, 320GB SATA drive and (I actually 🤣-ed when I saw this) a Q6600 🤣
Also a standard black-bezeled IDE DVD drive with lightscribe (which I'll probably never use).
The board only has a single bulging cap. It had no graphics card, but the Q6600 + compatible motherboard alone are worth this I think 😀
Also got a silver bezeled optical drive for €2,50...not bad, I basically just grabbed it after I had already decided on buying the €15 system.
My retro rigs (old topic)
Report spammers here!
Reply 17233 of 57671, by probnot
I like vintage things! I've fixed up a bunch of old tube radios, then got ambitious and picked up that TV with the plan of restoring it, but gave in and kept it as neat looking furniture.
Waaaaay better. Though the desk I use for old computers is tiny, so I haven't figured out how I'm going to fit these yet...
Reply 17234 of 57671, by mv_cz
Purchased this kit of HyperX memory modules for 1.25 USD 😁 Although listed as "256 MB" they are 512 MB total of course. I was little worried, because the sticker says they are 2.6 volts and my mobo can't run them on higher than default voltage, but they run happily with CL2-2-2-6 timings at 333 MHz (which is now limited by CPU) and default voltage.
The attachment DSC02095.JPG is no longer available
I'd like 1 GB total, but still... time to search for a second pair.
Reply 17235 of 57671, by The Serpent Rider
Typical Samsung UCCC DDR400 can run 2-2-2-5 DDR333 mode on stock voltage just as easily. In fact, even more older Samsung DDR333 256mb sticks were able to do it.
Reply 17236 of 57671, by brostenen
Bought a Commodore64 PLA chip and a socket for the chip. Hope I do not screw the soldering job up.
My machine begun to make some strange stuff. Poke 1,63 did not freeze it, and the diagnostic
program said that there are some timer issue and bad U5. Hope my reading is correct that it is the PLA.
Reply 17237 of 57671, by Matth79
Looks like a rebrand / copy of the Goodmans Active 75, might fine speakers for a 2.0, partly because they are rather larger than usual. That shape and layout is unmistakeable.
For a long time, my main set was a pair of Trust Soundwave 20 (also available in other names) smaller, but sounded much better than they ought for their size - got put away somewhere, missing, after the upstairs system got a 5.1 set.
Got a spare pair from charity shop for testing, a £5 pair of Goodmans Active 25, tiny but astonishing, nearly replaced the monitor speakers (ugh!) on the downstairs machine, but picked up another charity shop bargain, a 2.1 set of Altec Lansing Vs-2121 for a tenner
Reply 17238 of 57671, by kithylin
160GB IDE hard drive. It had a orange price tag on it. Found it bare hard drive with no static bag just sitting on the shelf with the rest of the junk in there. Orange tags were -75% off today. $0.85 after tax to walk out the door with it.
Working on testing it now.
EDIT: WORKS! Spins up, has a partition on it, read by windows.. performing slow error scan / surface scan with hdtune pro now. Only getting 37-38 MB/s over usb 2.0 but it's fine. Just leaving it going while I play games.
Reply 17239 of 57671, by xplus93
kithylin wrote:
160GB IDE hard drive. It had a orange price tag on it. Found it bare hard drive with no static bag just sitting on the shelf wit […]
Good find. Too many HDs are destroyed "for privacy" these days.
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
