First post, by fsmith2003
- Member
I have a Belkin Omniview Pro 8 port KVM switch that I have hooked up some computers to recently. One of the computers has a Voodoo 3500tv for its video card. It will not show up correctly when it is attached to this KVM switch. It defaults to 800x600 resolution and there is a lot of waviness to the video. However when it is connected directly to the monitor it looks fine and I'm able to choose different resolutions. Other computers have worked just fine with the same switch though. Are there any settings that I need to look into to get this too display correctly through the KVM?
