First post, by Timelord74
I can go through the install process as far as installing info.exe and then i get the following error
Error in 'copy'
no file or directory exists
then the install aborts..
Error in 'copy'
You will have to give more information than that, such as the exact steps you have taken, the mounting commands you used, etc.
Sounds like an attempt to install from an already installed copy...
Debian's fucked
Or running the install from the CD without having also mounted a "C:" drive.
