First post, by spirlet
Hi all,
I 'm new under Dosbox.
I'm trying to use a dos software but I already have an issue with Interrupt number.
I use the Dosbox initial configuration.
Some one can give me advice about this issue?
Thanks
    56.04 KiB
    89.55 KiB
    71.07 KiB
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Please do not make duplicate posts to get attention for your issue.
DOSBox is intended to run DOS games; DOS applications may not work fully or at all. Try vDosPlus or a different kind of virtualization. If some sort of special hardware for EDI is involved then a real legacy computer system may be your only choice, but perhaps only additional driver software is needed.
