440LX and 100MHz FSB
First post, by appiah4
I bought a Slot 1 mainboard thinking it was a BX but it turned out to be an LX.. How possible is it to run a 100MHz FSB PII CPU (say, a 350) on a 440LX motherboard stable at 100MHz? Do they even have this as an option?
Reply 1 of 22, by PhilsComputerLab
You can go with the top 66 MHz CPUs. I believe the Celeron 433, the Pentium II 333 or with a Slotket the Celeron 533.
YouTube, Facebook, Website
Reply 2 of 22, by clueless1
Yeah, you are stuck on 66 Mhz FSB. But you should still be able to run 100 Mhz FSB CPUs at 66 Mhz, albeit at slower speeds. Your best options are what Phil suggests above.
Reply 4 of 22, by Deksor
Can't faster celerons be run in these motherboards ? I think the fastest Celeron chip with 66MHz FSB is the Celeron coppermine 766. I've myself a Celeron 733MHz and I'm pretty sure that it could run without any problems in an LX board (maybe it will need some bios Update, maybe even some patching, but I don't see why it wouldn't work)
Reply 5 of 22, by Munx
440LX is capable for 83 Mhz with an overclock so I would suggest checking the Bios for OC options.
I doubt any LX boards can do 100, though.
My builds!
The Underdog - The budget K6
Reply 6 of 22, by nforce4max
I would use a high multiplier celeron and overclock the fsb, performance wise it should be very comfortable for most games of the period and later.
Reply 7 of 22, by Oldskoolmaniac
That board could be used for a gaming on a budget back in the 90's. How well will it perform! video, Something like that.
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 8 of 22, by melbar
Would be one option:
"Grab a Socket-370 to Slot-1 adapter, a Celeron 533, and crank your board up to the 75MHz FSB and you should be good to go."
http://www.anandtech.com/show/449/9
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 9 of 22, by DonutKing
I had a 440LX board in the day, and while it ran at 75MHz FSB fine, going up to 83MHz would cause HDD corruption, presumably because the PCI bus was running too far out of spec. YMMV.
Reply 11 of 22, by Deksor
Probably the PCI bus is running way out of spec and so the southbridge is oced as well. Can't you change dividers ?
Reply 13 of 22, by H3nrik V!
TheMLGladiator wrote:
SSTV2 wrote:
GA-686LX3 supports 100 MHz FSB.
It does, but the system crashes when trying to do anything (like install win98).
And as far as I can see, it is the "EX" chipset ..
Reply 15 of 22, by appiah4
rmay635703 wrote:
I have a celery 766
It's a coppermine Celeron though; does your LX board have the required VRM to go low enough on voltage for that?
Reply 17 of 22, by H3nrik V!
What makes you say that? I'm finding that the 686LX3 is an LX board.
Specifications on Gigabyte's website: https://www.gigabyte.com/Motherboard/GA-686LX3#sp
Reply 19 of 22, by TheMLGladiator
Yeah, the website spec sheet is completely wrong. Just looking a the manual(s) can show that all revisions use the the LX chipset. It does also help that I have the board in front of me 🤣
