Any ATX PSU with 30+A 5V rail?
First post, by Bobolaf
Are there any good ATX PSUs still being made with 5V rails of over 30W?
Reply 1 of 29, by firage
You're lucky to get 25A. That would probably be enough for almost any setup, but leaves absolutely no headroom.
I suspect that the voltages may go a little wild when you load a modern high watt PSU with more than 20A on the 5V rail while barely touching the 12V, regardless of printed specs. What you want is recommendations for tried and trusted PSU's.
My big-red-switch 486
Reply 2 of 29, by mrau
maybe this a somewhat stupid questions, but why not employ a DC/DC converter to boost 5v power?
Reply 3 of 29, by gdjacobs
That's essentially designing a new output stage. Nothing wrong with it, but it'll be a fair bit of work to do right.
Reply 4 of 29, by mrau
sorry, but i really don't understand that - why would one need to design this anew? just use part of 12v power line to boost 5v output - i can't imagine a dc/dc converter to introduce so much noise/instability as to disallow direct use on a 12 rail...
Reply 5 of 29, by gdjacobs
If the DC DC converter has a similar or lesser output impedance compared to the other supply rail, it will introduce significant ripple. An output filter will be pretty much mandatory. You would also have to properly ballast the two rails together and ensure that the new output network doesn't screw up the voltage feedback loop too badly. There's likely more to worry about, this is just a few things off the top of my head.
Reply 6 of 29, by nforce4max
Scrounge around for something of the period and when it comes in open the unit up so to inspect for rot cap then refurbish the unit. Brands like Antec, Enermax, and FSP ect made great performing units in the day however they did not age well especially Antec.
Reply 7 of 29, by deleted_Rc
no brand was excluded from the cap rot. Enermax didn't really make high quality ones rather the opposite. Antec and FSP made high quality but the caps were bad anyway.
Currently have a Hiper R and a Antec Truepower, while some people here were rather negative about the Hiper I couldn't help but notice it wasn't less quality compared to the antec.
Reply 8 of 29, by Tertz
Such PSU are almost not produced anymore. You may be lucky to find old model which was not in using.
There are still in shops high-end PSU like Corsair AX1200i with 30A, maybe other similar.
Among cheap with reasonable quality: FSP ATX-600PNR with 24A.
Also there are cheap "nonames", but I doubt you'd want to risk using them on retro stuff.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 9 of 29, by deleted_Rc
Tertz wrote:
Such PSU are almost not produced anymore. You may be lucky to find old model which was not in using. There are still in shops hi […]
My old corsair 750 had 3xA on the 5V which was from 2011, so 1200 is abit overkill and expensive too.
Reply 10 of 29, by Standard Def Steve
Keep a lookout for Zalman power supplies. They seemed to make some really nice PSUs back in the day. About a year ago I pulled a 400w Zalman out of a dumpster Athlon XP machine. The motherboard had bad caps, but the PSU (manufactured 2003) was absolutely perfect. It weighs a ton, has a very quiet fan, and an impressive 40A 5v rail. I use it to power my PIII, a Tualatin-1575 with 2GB of DDR and a GeForce 6800GT.
It's no dual Athlon MP, but hey, at least it's overclocked!
"A little sign-in here, a touch of WiFi there..."
Reply 11 of 29, by cj_reha
I am running a Kentek 680Watt PSU in my Pentium 3 box. It's probably a craptastic model, but it has served me well for about 6 months now. It's rated for...drumroll...50 amps on the +5 volt rail. Not sure how much truth is in that.
Reply 12 of 29, by Bobolaf
Thanks for all the replies there is some very useful information there. So it looks like my options are:
New very high wattage quality PSU.
New low cost / no name PSU.
New old stock older style PSU.
Used old style PSU.
Or I guess go down the server rough of dual PSU.
None are ideal unfortunately. I think I will have to go count my pennies and have a think.
Reply 13 of 29, by deleted_Rc
its posible, most likely they put down the maximum possible A used on the combined 5V en 3,3V rail which in this case should be atleast 250A, rather high but a dream come true for any Athlon XP build which usually requires around 30A on the 5V rail.
Reply 14 of 29, by gdjacobs
I feel the most optimistic result is that the PSU is generally okay but the paper rating grossly inflated. It's entirely possible this example is much, much worse, though.
Reply 15 of 29, by Ampera
I just checked the PSU that I use as the PSU of choice for my retro builds and it has a 38A +5V rail. It's truly the best PSU you can ask for with ATX retro builds. It has good -5 and -12v lines, a 20+4 ATX connector, not to mention a healthy combination of SATA, Molex, and FDD power. One of them has been in use for probably 4-5 years now and has not skipped a beat.
It is of course most any Logisys PSU that can be bought off of Newegg
https://www.newegg.com/Product/ProductList.as … 1624&IsNodeId=1
I have the 480w one in my Pentium 3, and a 550w one that was in my PC gaming rig up until a bit after I got my GTX 970, They can handle anything that doesn't need PCI-E 6 pin power pretty much.
Reply 16 of 29, by gdjacobs
I wouldn't trust your Logisys PSU based on their track record.
https://www.google.ca/search?q=logisys+teardo … d7jI-fKjwTLu74w
http://www.johnnylucky.org/power-supplies/psu … lemon-list.html
http://www.overclockers.com/logisys-ps480x2-review/
Reply 17 of 29, by deleted_Rc
gdjacobs wrote:
I wouldn't trust your Logisys PSU based on their track record. https://www.google.ca/search?q=logisys+teardo … d7jI-fKjwTLu74w h […]
I enjoyed reading overclockers post, gave me a chuckle.
Imo they should start make a higher standard for psu in the future to prevent garbage/hazardous psu to enter the market. They are a possible fire hazard after all.
I learned my lesson with a sweex PSU which exploded on me.
