First post, by Serious Callers Only
It's been a while, but i've been experimenting with my dosbox.conf files and i remembered.
Is 256 color mode somehow more compatible than the so called '64k' on the windows drivers with dosbox resolution change? I ask because, without 'fullresolution=original' (that also streches) on several win3.11 games .conf, and running windows 3.11 with 640x480 64k colors, the dosbox screen (and windows, and any game running) appear as a 'box' inside of a larger non-scaled fullscreen window (if fullscreen).
While if i use the 640x480 256 colors driver, my window is completely 'column boxed'.
I suspect this is a driver and nothing to do with dosbox right? Dosbox doesn't scale the image to fullscreen after windows boots, and my driver doesn't like the windows '64k' but is fine with '256', correct?
