First post, by sd6
I've split this into two threads for the same machine as they have a different purpose: My new osborne 486-photos
I picked up a Osborne 486 machine the other day slightly different to the model that has been seen on here before and defiantly one i have not seen before myself. Unfortunately the motherboard is destroyed, there is a massive burn mark on the board+ corrosion damaged from the cmos battery and several pins from the s3 graphics chip have come loose. I'd like to find a replacement motherboard that fits the case so i can get it up and running. Most the 486 boards i can find for sale online are not suitable and are regular AT form factor boards. I believe this is an lpx form factor and it uses a riser card to allow isa cards to be connected. Have found 2 ibm boards that look like they would fit for sale in the US but the seller wants over $200 just in postage which is ridiculous. Has anyone got anything that could help me out?
20170706_201222.jpg 20170706_201306.jpg 20170706_201338.jpg 20170706_201623.jpg 20170706_201900.jpg 20170706_201918.jpg
Reply 1 of 4, by amadeus777999
Shame... looks like it would have made a nice system.
On the other hand UK/Ukranian resellers seem to have a nice sortiment of these OEM boards for a good price... maybe you'll get lucky. Some time ago I spotted one with an on-board ET4000 chip but I highly doubt it was from an Osborne though.
Reply 2 of 4, by Deksor
I've got an IBM PS/Value that uses the same form factor and it has a VLB connector too.
The form factor in itself seems to be LPX. It's not completely standardized, but at lead this migh help you finding a new board that could fit in it
Reply 3 of 4, by chinny22
Looks like Gateway also used Micronics's motherboards.
http://webpages.charter.net/dperr/micindex.htm
Funny as they were not related at all at the time, but few years down the track Gateway would purchase the bankrupt Osborne Australia company
Reply 4 of 4, by sd6
So far the closest boards i have found seem to be out of ibm value point machines and some dells although on the dell boards the ps2 connectors are stacked on top of each other.
