First post, by mrau
hello,
i bought some time ago an asus radeon hd 6670 ddr3; while its a rather low end card i still have trouble cooling it properly, i even took off the cooling stuff, cleaned it and put some better cooling paste (same as on my 125W TDP CPU and here temps are rather same) on it but i still easily reach 70degC under load.
could anyone with more experience than me suggest what else i could do to cool this? this thing is rather slow, but the temps make it even slower due to throttle (cannot detect it properly, but i saw performance improve visibly with new thermal paste).
cooling of case is done via psu and rear fan;
m
Reply 2 of 6, by mrau
problem is, around 72-73 this starts to hang, even now in the eve, when it's cooler, and with a not very extreme load, it reaches 68.5-69 degC while the cpu is idling - this is too close for comfort...
Reply 3 of 6, by ODwilly
If it is a passive card add a fan. If t is not maybe add on of those blower cooler that adds a fan to the slot next to it.
Reply 4 of 6, by Tetrium
My HD6670 never developed these problems, but I remember it not being an ASUS. Mine was a Club3D with 1GB DDR3.
My HD 6850 is idling at around 58 degrees Celsius (but admittedly with the side panel removed till I replace the existing case exhaust fan), so 72 seems to be on the high side.
Personally I was kinda (pleasantly) surprised by the performance of my HD 6670 DDR3 compared to my HD 5670 GDDR5 I had in my main rig back then.
I noticed it seems Club3D quit making graphics cards last year and all the info on their website about them making graphics cards seems to have disappeared 😵
I'm sorry to see them go, it seemed like a good brand.
But if it's not the GPU, maybe it's the memory or some other component? Have you tried underclocking it to see if it makes any difference?
Maybe you could also just remove the side panel of your rig for the time being 🤣! Works for me! 😁 😵
My retro rigs (old topic)
Report spammers here!
Reply 5 of 6, by nforce4max
Had this happen to one of my cards and it is usually the result of a cold joint or a vrm issue but cards of this grade are so easy to cool. You can out just about anything on that card and it will get the job done, want a little retro in the mix consider a Zalman VF900 as it is all copper though the fan it has does suck which is why people do swap out the fan with something modern. Check the vrms and if any are Hot slap on a couple of cheap vrm or vram heatsinks then problem solved.
Reply 6 of 6, by mrau
thanks for the replies :>
i was thinking about some other cooler too, but i dont have any idea yet on how to install another one in a well chosen position
the memory is at 1600mhz cl9 so its nominal, it was for some time running at 1333mhz because mobo does not like it, but temps were the same;
underclocking might be an idea, but then it gets even slower than it is now..
the side panel is removed for this reason exactly :>
as for zalman - how would i make it cover ram too? the current radiator is just bad, an aluminum based star of some kind that looks beveled; i cannot imagine how air should travel on that thing;
