DOSBox SVN Builds
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: DOSBox SVN Builds
Postby James-F » 2017-5-10 @ 04:38
As of SVN r4012 Gobliins 2 sound is still a mess.
User avatar
James-F
Postby Dominus » 2017-5-10 @ 06:57
This is not the right thread for bug reports. Start a new one and make sure to try a vanilla svn build
User avatar
Dominus
DOSBox Moderator
Postby James-F » 2017-5-10 @ 10:13
Thanks Dominus.
I am registered on SourceForge so the bug reports go there, but is it wise to start a new thread for a small bug report or comment?
User avatar
James-F
Postby Dominus » 2017-5-10 @ 13:44
As part of some other projects *I* like single bug reports better. I have had the experience that bug reports in other threads tend to get lost in the noise and derails threads. This thread is a prime example as it was intended to list the varios SVN builts that are available. It has long been derailed, though ;)
So my thoughts are its best to log a proper bug report on SF and start a new thread unless it kind of fits in another thread. Here I think the ECE thread would have been more appropriate sine the problem started with the changes discussed there. But then again that thread has been derailed as well ;)
Edit: but then I'm only speaking from my experience, I'm only a moderator here, not a DOSBox developer ;)
User avatar
Dominus
DOSBox Moderator
Postby ETPC » 2017-7-13 @ 00:41
Is it still a good idea to use Daum's DosBox build? I really like it's ease of use, it's features and it's UI, but it's super behind actual DosBox builds. Has anything surpassed it for usability?
ETPC
Postby collector » 2017-7-13 @ 00:52
It is also broken.
User avatar
collector
Postby ETPC » 2017-7-13 @ 01:20
collector wrote:It is also broken.
Ooof. Is it really? That might explain a few things.
So what should I switch to nowadays?
ETPC
Postby gdjacobs » 2017-7-13 @ 04:25
ECE if you like the bells and whistles.
User avatar
gdjacobs
Postby ETPC » 2017-7-13 @ 23:17
ECE seems pretty great, but I'm gonna miss the UI of Daum's. :(
ETPC
Postby gdjacobs » 2017-7-14 @ 03:23
Probably worth the trade to get working software and a developer who's still active.
There's also quite a few frontends in active development to make setup more pleasant. If you have specific features you want included, try to find one with a developer team which allows you to actively contribute via your ideas, testing, coding, and encouragement.
User avatar
gdjacobs
Postby Serious Callers Only » 2017-7-22 @ 15:50
The thing about the (G)UI that makes it a feature not just a convenience is changing the defaults of the conf file(s) as the game is running, not just at the start, if for some reason you can't or don't want to change your defaults for that game (i know about dosbox support for 'onion' confs).
Though, it's not surprising that that fork/patch is dead honestly. GUIs are always messy platform specific things, and when you have multiple unrelated dosbox patches with new options on top...
I sure won't put such a patch in my ppa even if it existed.
Postby gdjacobs » 2017-7-22 @ 16:42
Well, if you had real hardware, you wouldn't be changing much in the way of configuration details without a reboot.
User avatar
gdjacobs
Postby Serious Callers Only » 2017-7-23 @ 12:39
Eh. What does it mean to change the scaler on 'real hardware'? Some settings don't have a equivalent. For sure, if it's dangerous to change it outside of the shell, by all means disable it, but some are perfectly safe.
Postby gdjacobs » 2017-7-23 @ 19:20
Serious Callers Only wrote:What does it mean to change the scaler on 'real hardware'?
Changing monitors, of course!
User avatar
gdjacobs
Postby marooned_on_mars » 2017-8-04 @ 02:06
Speaking of scalers, is it still normal for scalers to not work with machine=vgaonly in the latest CVS version? (r4025)
Tried using it with scaler=normal3x and aspectratio=true, but it doesn't work, instead I get a weird normal2x scale with ugly stretching.
Also been getting a lot of buffer underrun errors with ALSA (Debian Sid), so I wonder if anyone has such problems as well.
I support Universal Basic Income, and so should you, here's why. Another reason why.
Commonly asked questions about UBI
Spread the word!
User avatar
marooned_on_mars
Postby Paljas » 2017-8-14 @ 23:22
Is there any more up-to-date build than Daum that has pixel shaders? Daum works most of the time but some games don't work (which do work in the main build).
Paljas
Postby roytam1 » 2017-9-10 @ 09:38
I found that r4044 runs extremely slow when starting RICH3. (rths.cf/tmp/rich3.zip)
roytam1
Postby Ant_222 » 2017-9-24 @ 16:31
Paljas wrote:Is there any more up-to-date build than Daum that has pixel shaders? Daum works most of the time but some games don't work (which do work in the main build).
There is a branch with OpenGL shaders.
Ant_222
r4059 crashes when closed
Postby Yesterplay80 » 2017-10-13 @ 07:06
My latest builds of DOSBox SVN r4059 crash whenever I close them via the "X" in the title bar. Closing it by entering "exit" in the DOSBox windows works, however. I tried it on several PCs, it happended all the time. Can anyone confirm this error?
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Re: r4059 crashes when closed
Postby gandhig » 2017-10-13 @ 07:43
Yesterplay80 wrote:My latest builds of DOSBox SVN r4059 crash whenever I close them via the "X" in the title bar. Closing it by entering "exit" in the DOSBox windows works, however. I tried it on several PCs, it happended all the time. Can anyone confirm this error?
Yes, confirmed from my side. It wasn't there in old versions, atleast in r4019.
One more thing observed, more like a minor regression, is that the load time between the title screen and game screen has increased considerably in Lure of the temptress since r4047 commit(MPU related!!!). In older dosbox builds, the blue note symbol on bottom left used to flash only once between the title screen & prelude(text) as well as between the end of prelude & initial game screen. But since r4047, the blue note symbol flashes 10-11 times in both instances in my system
User avatar
gandhig
Location: Unknown...yet. Triangulating inside...Level 1
PreviousNext
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 2 guests
