First post, by Jed118
So I've always wanted to build a 286, and lately I was really reminiscing about the time I built a good friend a 286 with spare parts I had in grade 8. From what I recall, his was probably a 12 MHz, 3Mb RAM and a basic era correct hard disk - It had one thing that I really would like to find - EGA.
I've been amassing parts in Poland through their version of eBay and I got (for about $90) all the parts I needed to build a 286. Interestingly, the case I picked up had a "dead" 386 DX-40 which restored itself to working order after I took the RAM out and took a white eraser to the contacts - Score, that'll be another build for another thread.
Onto the 286 itself - I've got a flip top style case, 1.2 and 1.44 Mb floppies, a Headland generic 286/16 MHz board, 512K VGA video, ISA controller, and a 43Mb IDE Seagate disk. Like my 386SX system, this one accepts DRAM and SIPP, but the configuration I've chosen does absolutely not work together ๐Ÿ˜ต So, it will stay as 1 Mb for now. I used era correct parts as much as I could. In the future, I will try to get an AdLib or an 8 bit soundblaster for it.
First, the case:
A bit beat up and definitely yellowed.
This is the motherboard - I've removed the offending cell and replaced it. I did my best to clean as much as I could, but some minor corrosion exists in the expansion slots (Yes, I took the BIOS chips out and cleaned underneath them)
Sub components:
The hard disk: It came out of my 386SX which got an upgrade to an 85 Mb Conner drive (no bad sectors!)
I haven't seen these standoffs in over 20 years:
I had to take out the power supply to get it connected to the motherboard:
Performance! It increased after I tweaked the BIOS
Yellowness
Shit, no room to eat breakfast
Never mind, found a spot:
More yellowness:
Now, to remove the yellowness. Disassemble the yellow components:
Apply the hydrogen peroxide gel
Wrap it in saran and let it sit for a few hours, rotating as necessary:
Rinsed parts:
It ate my ESCOM sticker, but I have a good one to replace it with once I find it. Also, the computer came with a warranty booklet underneath, all in German.
This is a happy little computer now:
This is the best I could do with ABS glue -
Looks like I'll be retrobrighting the monitor next!
What's for sale? my eBay!
Reply 1 of 6, by Jo22
Congrats on a job well done! ๐Ÿ˜ It's really cool to see someone puts his/her heart into restoring 16-Bit machines! ๐Ÿ˜Ž
Normally, 286 chipsets can handle 4MiB without a hassle. You can make your own SIPPs, by using four SIM modules with one MiB each.
I tried this myself and it worked every time sofar. Initally, I used resistor "legs", but also pin strips later on.
With 4MiB of RAM, you're nolonger limited to Win 3.0 also. In fact, Windows 3.1 (or 3.0 MME) will fly like a bird with a jetpack. ๐Ÿ˜‰
If that's to much work, you could also order an EMS card kit from Lo-Tech. I just tried an AST Rampage 286, btw - it can do both XMS/EMS, I believe.
In theory, EMS can also be used by Windows 3.0 in Real-Mode. So you can enable wall papers and run larger Windows programs.
I don't know if the whole thing works with Lo-Tech cards, though. ๐Ÿ˜• Perhaps that feature requires EMS with a page frame larger than 64KiB..
Sorry, can't confirm. I tried that (Win3.0+EMS) once with EMM386/MemMaker on a 386 and it worked fine there.
It also worked with Windows 2.03. But that version can only pass available EMS to EMS-aware programs (DOS/Win),
but cannot provide extra memory to normal Windows programme.
Reply 2 of 6, by Jed118
Thanks! That's what I think I will do... I just wanted to use up those damn SIPP chips but noooooo they won't work together at all.
Next time I see some cheap 1Mb SIMMS, I'll grab them and convert them to SIPP. Or, if I can find SIMM slots, I'll go the route someone suggested in my 386SX thread and plop those into the SIPP slots and then just use SIMM RAM that way.
Now I have to read up on EMS/XMS memory and optimize this baby, maybe play some Prince of Persia tonight on it. Maybe benchmark it with something concrete too.
Interestingly, this thing is over a year *newer* than my SX - And my SX board is larger and with more discrete things on it. This must have been one of the last boards of the 286 variety.
Oh how I wish I could have EGA... ๐Ÿ˜
Reply 3 of 6, by deleted_Rc
Looking good, no bleach marks or atleat non visible ๐Ÿ˜Š also beautiful case.
Reply 4 of 6, by Jed118
I'm gonna try to spray it on next time using a nozzle off a liquid weed spreader and a 12v washer pump motor to ensure even coverage, and not wrap it.
But yeah, no streak marks.
Reply 5 of 6, by ScoutPilot19
Leica camera spotted ! IS it film or digital ? )
Reply 6 of 6, by Jed118
It was a 1968 35mm - I found it at where I work, as they were clearing out the labs to modernize them. I sold it on eBay and let's say it funded a whole bunch of upgrades on my project car (tires, spacers, brake pads, monotube shocks for the rear and some Compact Flash card goodness for my 386/486 systems) ๐Ÿ˜
