Finding bugs in 8086-80386 emulation core?
Reply 20 of 142, by peterferrie
You have a bug in popa. Compare:
00:03:56:75.07504: 0000:7D3C (60)PUSHA
00:03:56:75.07504: Registers:
00:03:56:75.07520: EAX: 00000000, EBX: 00000700, ECX: 00000001, EDX: 00000000
00:04:10:57.06960: 0000:7D71 (61)POPA
00:04:11:20.06368: EAX: 00007c7a, EBX: 00000000, ECX: 00000000, EDX: 00000001
Looks like a stack imbalance. From there:
00:04:30:64.06528: EAX: 00000201, EBX: 0000007c, ECX: 00000029, EDX: 0000c3c0
This request fails, and you get the crash.
Reply 21 of 142, by superfury
Something I do notice, is that the SP register is exactly 0x10 higher after the INT 13h call returns(with 4 bytes in memory being skipped in the log). So maybe some problem in either the INT13h handler is occurring, or the code that executes directly after it returns(those missing 4 bytes of instruction data in the log) does something to the SP register?
UniPCemu Git repository
Reply 22 of 142, by superfury
Looking at the instruction directly after returning from the interrupt 13h handler: it's an LEA SP,[DS:SI+10], which is encoded as 8Dh, 64h, 10h at 0000:7D6E. Then it gets to the POPA instruction, which is popping the wrong data.
Reply 23 of 142, by superfury
This is a newly made log of the current commit of UniPCemu:
debugger_20170717_2128_complete.zip
220.96 KiB
56 downloads
Latest dump of Windows 95 volume boot sector executing.
Reply 24 of 142, by superfury
Thinking about it: SI should be 10h lower than the address of the place the PUSHA has pushed it's data? So the value of SI should be 0x7BAE, according to the instruction after the INT 13h(0x7BBE minus 0x10) and after the PUSHA?
Edit: Just looked for occurrences of "SI,"(without quotation marks). It only looks to be used and modified at a few places, but they should've been intentional?
Reply 25 of 142, by Jepael
So do you correctly handle size override prefixes (66)?
For example, it's 16-bit code, so all data and address sizes are 16-bit unless data/address size overrides are used.
6a XX : push imm8 as 16-bit word
66 6a XX : push imm8 as 32-bit doubleword
Reply 26 of 142, by vladstamate
Does 66 6A XX modify ESP or SP ?
What about 67 6A XX ?
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 27 of 142, by superfury
The operand size override will make it push/pop 32-bit registers and data on the stack and move stack data up or down 4 instead of 2 bytes(+/-=4 vs +/-=2) in real mode.
The address size override(0x67) has no effect on stack, only modr/m and mov [imm16/32],al/ax/eax instructions. So it's ineffective with PUSHA/POPA.
The code segment descriptor D-bit determines the default operand size. This is flipped by the operand size override.
The stack segment descriptor B-bit will make the stack use ESP instead of SP.
Those overrides are unused with the mentioned code that's running.
Edit: The immediate stays 8-bit, just pushing 32-bits of data on the stack(zero-extended), decreasing SP with 4, when used with the operand-size prefix. Address size prefix has no effect.
Reply 28 of 142, by vladstamate
No it is not. 0x6A is PUSH imm8. I know your code had PUSHA as the opcode in question but I guess me and Japael meant PUSH imm.
Providing a 16bit segment. If I have the 66 or 67 prefix, will ESP or SP be modified? I assume 66 pushes a 32bit value on the stack and 67 modified ESP.
Reply 29 of 142, by superfury
Currently, 66h works as you say. But 67h only has effect on modr/m and mov to/from al/ax/eax with immediate offset(opcodes A0-A3).
Wouldn't it cause problems if the stack size(SP vs ESP) can be overridden by 67h? Like with 67h PUSH [DS:ESI]? So both the parameters to store data(DS:ESI) and the stack itself((E)SP) would switch? That shouldn't be the case?
Edit: https://c9x.me/x86/html/file_module_x86_id_269.html confirms this, basically.
Edit: http://www.felixcloutier.com/x86/PUSH.html also confirms only the SS Segment Descriptor B-bit is used to differentiate between SP and ESP during stack accesses.
Reply 31 of 142, by superfury
I've just fixed a little bug in the FDC seek/recalibrate(Missing seek bit in MSR and IRQ) and Specify(Missing IRQ) commands. Now the Compaq Deskpro 386 BIOS hangs with POST Diagnostics code being A8? So problem detecting drive type? AT still fails the FDC after seeking?
Edit: Looking at the executed code, it keeps executing the same code in a loop after setting drive 3 motor to ON:
Looptop:
IN AL,40h
MOV AH,AL
IN AL,40h
SUB AL,AH
JA Looptop
Looking onwards, I see the BIOS setting 40:90 to 00h, with no new FDC commands executed after that? The hang seems to be out there?
Log made of the BIOS running:
https://www.dropbox.com/s/im4907h8vm98uja/deb … 24_2113.7z?dl=0
Reply 32 of 142, by superfury
Having looked at osdev.org's FDC information, my Floppy Specify command(a.k.a. Fix drive data) was generating an IRQ, which it shouldn't(apparently). Fixing this, the Compaq Deskpro 386 BIOS boots without problems again.
Reply 33 of 142, by superfury
I'm trying to get the FDC working properly again on the XT(with a 80386 without any waitstates for faster testing), but for some reason, my floppy disk boots fine, until it's past the HIMEM.SYS driver, after which the floppy disk controller goes awry for some reason? It says:
Bad or missing VIDE-CDD.SYS
Error in CONFIG.SYS line 4
HMA not available : Loading DOS low
Not ready reading drive A
Abort, Retry, Ignore, Fail?
The FDC data shows that the last (correctly) executed command was a Specify command. The MSR is 0xB0, the floppy being ready to receive a new command. Specify doesn't raise any IRQ(which is according to various sources, like osdev and 82077AA datasheet). The MSR isn't read(and updated as such) after the specify command received it's parameters and executed.
Reply 34 of 142, by superfury
This is a log of the entire FDC booting MS-DOS 5.0 with HIMEM.SYS, then failing on the remaining parts:
40.65 KiB
Screen capture directly after the log.
debugger.log
369.52 KiB
41 downloads
Floppy disk log of everything the FDC does and gotten reads/writes.
Can anyone see what's going wrong?
Reply 35 of 142, by superfury
I've just tried copying the Windows 3.0 setup files(valid files) from CD-ROM ISO image using the Compaq Deskpro 386 emulation, then installing Windows 3.0 on the NEC V30 XT configuration. The AT drivers(himem.sys, vide-cdd.sys) abort loading because of the 'non-x86' CPU(although it might need a 32-bit x86 CPU, so it means IA32 instead of x86-16? Then it continues loading the remaining drivers(ctmouse.exe and mscdex.exe), where mscdex fails because no drivers for the CD-ROM(vide-cdd.sys) are found. Then, when I start setup.exe(the files check out being copied correctly by extracting them using Winimage and using Winmerge to compare the directories) everything works correctly, until it starts the kernel/win.com(black screen after copying the first two disks). At that point, the application hangs because of an unknown CPU bug.
So that means the 8086/80186 emulation cores have a bug(NEC V30 is actually a 80186, with 8086 cycle-accurate timing and 4 cycles/instruction for all 80186 instructions EU timings)? Is there a good way to find the offending instruction?
Reply 36 of 142, by superfury
Trying to find a simple testsuite for the 80386 leads me to this: http://marc.info/?l=bochs-dev&m=124236420804902
But, unfortunately, it seems to contain stuff for an FPU and/or newer unsupported CPUs as well. Currently only up to 80486SX is implemented(Pentium would be tough, seeing as it has parallel processing etc., so I doubt I'll start on that anytime soon(also the caches are going to be hard to implement, let alone with speed).
Are there any testsuites for 80386(all instructions/opcodes) available?
Reply 37 of 142, by superfury
Just tried installing Windows 3.0 with the CGA emulation and NEC V30 XT(80186) configuration. Windows 3.0 setup continues past given point, until it gets to disk 4, after which the keyboard becomes unresponsive for some unknown reason. Restarting win.com from the command line makes it continue at disk 4, while also not receiving any keyboard input. Since the CGA drivers don't use any 80186 instructions(afaik), that means there's a serious problem with the 8086 emulation core?
8086 emulation core: https://bitbucket.org/superfury/unipcemu/src/ … 086.c?at=master
Reply 38 of 142, by danoon
I also was unable to find any test suites for x86 emulation when I was working on jDosbox. The closest I came to finding one was for the FPU. I ended up writing my own unit tests, but it's not complete, it mainly deals with math instruction and making sure I handled flags correctly. Even though it took a while to write, I believe it more than paid off, especially when I tried to come up with a new core. I would recommend the same for you. And I feel you pain on debugging those issues. I was spent 2 weeks tracking down a single cpu bug that prevented Windows XP from booting.
https://sourceforge.net/p/jdosbox/code/HEAD/t … u/instructions/
http://www.boxedwine.org/
Reply 39 of 142, by superfury
Currently converting much of the Ev vs Gv logic to use the lookup tables instead(only up to 80186 so far), but for some still unknown reason, the Turbo XT BIOS crashes on the VGA, according to it's beep codes(not crashing 2 commits back). I'm also considering converting the protection/interrupt module to become fully cycle-accurate(e.g. Using the BIU to fetch all data, needing to interrupt execution in between), but I'm not sure what's the best way to implement that change. How does a real CPU handle this? Does it contain some microcode to handle that(everything protection/exception/interrupt/task switch-related)? Are those supposed to be one execution path? Is the path aborted during exceptions/task switches executing a path? How does a real CPU handle this, theoretically? What kind of 'scripts' does it run to handle all those(probaby implemented in microcode)? I need to make it in some semi-script form in order for it to be made compatible with the cycle-accurate BIU(which can halt the then-used script while it's fetching data from RAM or storing data to RAM). Of course, exceptions terminate the script and starts a new one(for the exception handler, resetting all registers to the current task state or instruction state(in real mode).
Current commit(which breaks emulation, causing the VGA BIOS to fail): https://bitbucket.org/superfury/unipcemu/comm … f8647?at=master
Two commits earlier( https://bitbucket.org/superfury/unipcemu/comm … f7abf?at=master ) still ran without known problems(on the 8086/80186 core).
Can anyone see the error(s)? Why is the VGA BIOS failing? Anyone has any ideas on implementing the protected mode features using such a (semi-)script(still plain C though)?
