775i65G AGP beast
Reply 40 of 62, by PCBONEZ
Yes.
I think the change to all solid polymer caps is why the cheaper brands or models appear to be better than they used to be.
The slow switch to all polymer was partly a cost issue and partly a technology issue.
In the early 2000's solid polymer caps that cost 75-80 cents each today cost $12-$15 each.
And until fairly recently the available uF and voltage ratings of solid polymers couldn't cover the range of wet-lytics.
They still don't -quite-, but almost.
Back to Asus:
If you think back you'll probably remember ads for industry standard RAM that said something like -
"Compatible with all ___ chipset motherboards - except Asus."
I suspect that is/was because Asus was cheaping-down by not using the recommended (by AMD/Intel) small SMD noise filtering parts near their RAM slots.
RAM that had those parts in excess of the minimum on the module (which is optional) would work but RAM that didn't wouldn't always.
Reply 41 of 62, by matze79
ratfink wrote:
swaaye wrote:
lol […]
check out this other board they make. AM2+ plus real AGP 8x and PCIE x16 enabled by using two chipsets! SATA 2, GigE. Insanity.
http://asrock.com/MB/overview.asp?Model=ALiveDual-eSATA2
ASRock engineers are crazy.
That board's been in our main pc for a few years. Also running a couple of 4coredual's, the socket 775 equivalents. Were a godsend when the switch to pci-e was happening, and now they give nice flexibility still - got one 4coredual with a dual core cpu and pci-e card, the other has a prescott and fx5950 ultra. alivedual has an x4 phenom.
Pretty uncombatible.
http://asrock.com/support/note/AM2NF3-VSTA.html#Phenom
Looks like with Phenom X4 you get only PCI Mode AGP (x64).
Reply 42 of 62, by PCBONEZ
Dupe - double post - sorry.
Reply 43 of 62, by Zollex
Hi! I lost bios 3.2+ for Wolfdale
Where can I download?
Reply 44 of 62, by agent_x007
ASRock main site has v3.30 : LINK ?
Reply 45 of 62, by Zollex
I need bios mod 3.22 for Wolfdale, not official bios, fool!
Reply 47 of 62, by agent_x007
Source : LINK
Reply 48 of 62, by Zollex
Are you kidding?
Reply 49 of 62, by GeorgeMan
vetz wrote:
No reason to call him fool, he only tried to help.
Probably due to bad English though. 😊
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 50 of 62, by boxpressed
A little bit of a necropost just to say how wild this board is. I got mine in a lot with some other LGA 775 boards without even knowing it was in there. It's a Rev 3.0 too. I vaguely recall the hubbub on Vogons a while back when you could get these new for $50. I added a Pentium Dual Core E5800 ($6) and 256MB of CAS 2.5 DDR memory.
I had my doubts, but I downloaded the Windows 98 drivers from the Asrock website and proceeded to install 98SE. Everything installed perfectly. USB 2.0 without any of the headaches usually associated with Windows 98 and USB chipsets.
I haven't even added any video or sound cards yet. I'm using the integrated graphics from the 865G and the C-Media AC'97 audio. Just for kicks, I benched Unreal Gold at 1024x768 and got 44 FPS.
I'll probably add an XP HDD too, but right now I'm intrigued by having one of the fastest Aureal 3D builds around. I knew I was saving this X800 AGP card for something.
Reply 51 of 62, by Zollex
Unfortunately the rev. 3.0 does not allow to use the E7600 cpu ... Maybe changing the bios ...
And I can't dual-boot 98-XP.
Reply 52 of 62, by Srandista
Zollex wrote on 2020-05-06, 22:03:
Why, what's the issue?
Reply 53 of 62, by Zollex
At dualboot, If I select Win98... error "No G2LDR".
Reply 54 of 62, by Srandista
Are you using or used Linux on that machine?
Reply 55 of 62, by Zollex
No, no!
Reply 56 of 62, by Srandista
Try repair bootloader with Windows XP CD.
https://neosmart.net/wiki/no-g2ldr/
Also, for dual boot to work correctly, you need to first install 98 and XP afterwards.
Reply 57 of 62, by Scraphoarder
I also have the rev.3 .0 and tripple boot 98SE, XP and 7. Found a nice guide for how to do it, but didnt bookmark it..
Reply 58 of 62, by kalohimal
This is a very good board that is able to run DOS, Win 98 and XP games all in one machine.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 59 of 62, by tanasen
boxpressed wrote on 2020-05-06, 21:51:
Have you tested the C-Media chip in DOS? Does it work? Also, how does the A3D and EAX sound like? In the CMI8738 that I've tested it isn't that good.
PC1😜 III-S 1.4GHz, GA-6VTXE, 512MB SDRAM, Albatron FX5900XTV 128MB, SB Live! 5.1
PC2😜 III 800MHz, MS-6178, 256MB SDRAM, 3DFX Voodoo3 2000 PCI, Creative CT4810
PC3😜 MMX 200MHz, SY-5EAS5, 128MB SDRAM, Diamond Monster 3D, Diamond Viper V330, ESS 1868F
