First post, by Moogle!
One of those full AT systems with discrete logic and that one VLSI chip? There is an example on the Redhill website here, (scroll down), though there are a few variants. They were usually sold by Amptron/DTK, and I (maybe) have found an AMI one.
How well does they work? Will one go to 33 or 40 Mhz?
Reply 1 of 28, by Jo22
Moogle! wrote:
There is an example on the Redhill website here, though there are a few variants.
I got this error message: http://redhill.net.au/hotlink-error.png
Edit: I assume you meant the "DTK PEM-2500 Cache 386" model at http://redhill.net.au/b/b-92.html
If that link doesn't work, go index->mainboards->Golden oldies for 286 and 386
Reply 2 of 28, by Unknown_K
I have a couple early 486 boards with a million chips on them, freaking huge.
Reply 4 of 28, by Jo22
Once, I had got an AT mainboard with about the same size..
Moogle! wrote:
How well does it work?
The board I once had worked just fine, even came with some diagnostic software built-in.
Hard to tell. Perhaps? It would require some heatsinks and/or faster ICs at some point. Also, the long traces don't do higher frequencies so well.
If it's just about CPU clock speed, a Cyrix 486DRx2 could do. It has a clock-doubling feature and runs on 25MHz bus frequency, too.
Don't know about the cache feature, though. Mainboards so ancient may or may not have the socket wired up for that.
Reply 5 of 28, by Moogle!
Anonymous Coward wrote:
Yours is built by AMI, or does it just have an amibios? AMI boards are nice.
Not mine, just one I was looking at (edit: may or may not have been). They're kind of rare, but AMI did build actual boards, and you can find some instructions manuals on their website.
Ironically enough, they don't generally provide bios updates, or I haven't found them.
Some of them did. That one listed in on RedHill actually does.
Reply 6 of 28, by pauls640
I have one of them, it'a PEM 2500, a 386 board. It's one of my best guarded treasures 😀 . It came with a 386-25 onboard. I want to do some fancy project with it, at the moment is sitting unused.
Reply 7 of 28, by 386_junkie
A also have one of these rare animals... built by DTK it is a PEM-3334D, with DTK and VLSI chipsets.
Though it is a full length AT size board, not those huge AT boards, and comes with a 66MHz OSC onboard for 33MHz FSB.
Reply 8 of 28, by feipoa
I have an AMI one, full-size with VLSI, however it doesn't seem too keen on clock-doubling feature of the DRx2 or SXL2. I need to investigate this further at some point. The 40 MHz SXL, DLC, i386, and AMD 386 work fine though.
Reply 10 of 28, by feipoa
You are probably right. I just clicked on the link provided and looked at the first and second photo, however I agree, he is probably referring to the 3rd photo down, in which case, nope - don't have one of those anymore.
Reply 11 of 28, by luckybob
Well, I don't have a full AT 386 BUTTTTTTT..... I do have two FULL AT dual socket 8 motherboards. I have pics in this thread: Bitchin' dual p-pro setup
Reply 12 of 28, by 386_junkie
Err, I think the poster is asking about full size AT 386 boards, not full length baby AT.
Having discovered the DTK board I picked up... I found that the full length boards were the last in the series of 386 DTK boards... which started off with 386SX boards... and those huge AT variants.
It's evolution... would be interesting to see, all things equal, tests between a discrete logic AT DTK board and chipset full length DTK board.
Edit; -
... i.e. A DTK PEM-2500 v DTK PEM-3334
Reply 13 of 28, by pauls640
386_junkie wrote:
Having discovered the DTK board I picked up... I found that the full length boards were the last in the series of 386 DTK boards […]
Edit; -
That can be sorted out, cause I also have a full lenght baby AT, it's not from DTK though. I suspect that the baby AT is faster, because of the more modern chipset and the smaller size.
Reply 14 of 28, by tikoellner
I happen to have one of these full-sized AT boards. It's a Unisys PW2 800 system board. I believe it was actually made by Micronics.
The board runs (yep, it works) on i386DX-20 along with i385 cache controller and i387 coprocessor. It has 32kb of cache. There are some nice jumper cables which seem to to mean an early revision (?) The chipset is based on two Zymos chips: Poach 1 and Poach 2. It also has built-in WD serial/parallel controller. Some propietary expansion slot I know nothing about.
I love the board. Unfortunately I could not find any reference and don't know how to set the jumpers and switches.
Reply 15 of 28, by pauls640
A quick note on the DTK PEM 2500 motherboard: if you read the article provided by OP, they state the mobo is from 1990, because they looked at the BIOS copyright date, but in fact the product was selling in 1989 as well, as you can see from this ad on Infoworld : (https://books.google.it/books?id=czAEAAAAMBAJ … e%20386&f=false)
What happened here is that they designed this board a year or two earlier, and decided to keep alive the design to accomodate faster 386's, probably because the whole project was costly, and performance of the board was decent enough.
The board in fact can run a DX-33 (as you can see from this ad), but I think it's slower than a more modern board.
I'll take advantage of a rainy weekend, and make some benchmarks 😉.
Reply 16 of 28, by evasive
tikoellner wrote on 2017-09-26, 22:01:
I happen to have one of these full-sized AT boards. It's a Unisys PW2 800 system board. I believe it was actually made by Micron […]
Well, 2 years later we started building a database and guess what, I think I found your board:
https://theretroweb.com/motherboards/s/acer-m … f-pc-1100-25-33
Reply 17 of 28, by rmay635703
I’ve owned multiple gigantic DTK 386sx motherboards in the original case.
Personally have always found that vintage DTK with the big red switch in the rear ugly but they are reliable
Reply 18 of 28, by Horun
I have a giant DTK PEM-3301 386. It works well but is huge :p
Reply 19 of 28, by mbalmer
Horun wrote on 2022-08-31, 23:39:
Sorry for the necro here, but I thought I would ask: I just got my hands on one of these boards with the original DTK BIOS, but I'm hoping to see if there's a working BIOS to compare mine to as for some reason, the BIOS process stops just as it's about to count RAM. Do you happen to have a dump of the ROMs for your board? For reference, mine are labeled as version 4.26.
