AUDIO - Nuked OPL3 Patch for DOSBox(+Windows build) (SDL1)
Here you can discuss the development of patches.
Re: Nuked OPL3 Patch for DOSBox(+Windows build)
Postby nukeykt » 2017-6-10 @ 18:11
Battler wrote:So basically, all I need to do is not map the high bank, and that's it?
Yes. For single OPL2 it's enough. But you should emulate somehow Dual OPL2.
nukeykt
Postby Battler » 2017-6-10 @ 18:45
The emulator already has something for that, opl2_r read/write and opl2_l read/write, each going to its own OPL2 chip. Hopefully I can just reuse that.
Battler
Postby James-F » 2017-7-31 @ 06:43
Hi nukeykt.
Will NukedOPL v2.0 be available as a patch?
User avatar
James-F
Postby nukeykt » 2017-8-01 @ 15:29
James-F wrote:Hi nukeykt.
Yes. When i'll finish it.
nukeykt
Postby FM-OPL-Midi-Freak » 2017-8-21 @ 18:47
Hello all!
please, can anyone tell me, how can install the patch file, the content of the"dosbox-nuked-opl.zip" I just replaced with the original dosbox.exe and the corresponding *.dll´s "SDL_net / SDL.dll,
For answer I am grateful ;-)
Greets
Matthias
Equipment:
- ESS Solo (PCI)
- Ess Audio Drive-Compaq (ISA)
- Soundblaster 2.0
-Audioblaster Pro 4.0 at the time puplished by CPS Hamburg
-Sw1000XG / Motif XF - my treasures ;-) beside the Cockaigne of fm synt synthesis / adlib
FM-OPL-Midi-Freak
Re: AUDIO - Nuked OPL3 Patch for DOSBox(+Windows build) (SDL1)
Postby Uriel_Dagda » 2017-12-03 @ 04:09
I'm using the DOSBOX ECE... I'm using my old DOSBOX conf file that was made by GoG for World of Xeen--- is oplemu the same as oplmode?
Uriel_Dagda
Postby NewRisingSun » 2017-12-03 @ 04:17
nukeykt, I noticed something when I used the YM3812-bearing CT1320 in my Tandy 1000 TX.
Most documentation states that the YM3812 can be distinguished from the YMF262 by reading the index port; a YM3812 supposedly always returns 0x06, while an YMF262 supposedly always returns 0x00. Well, on the Tandy 1000 TX, reading the index port only returns 0x06 if you write a byte with bits 1 and 2 set immediately to it before! Unlike standard ATs, the Tandy 1000 TX does not pull "open bus" bits high. That also manifests itself in reads from unmapped I/O ports returning whatever just happens to be on the bus, while on a standard AT, reading unmapped I/O ports always returns 0xFF.
Can you confirm that on the YM3812, index port bits 1 and 2 are open bus rather than "1" bits from the chip side?
NewRisingSun
Postby nukeykt » 2018-3-30 @ 10:41
Nuked OPL3 v1.8 is out.
Changelog:
* New envelope generator.
* Rhythm mode emulation is 100% correct now.
These and other aspects of chip have been verified on YMF262 die shot, so emulation should be perfect now.
P.S. For some reason i can't edit topic's header. So i'll attach patch here.
You do not have the required permissions to view the files attached to this post.
nukeykt
Postby appiah4 » 2018-3-30 @ 11:04
Can this be somehow used with the stable branch of Dosbox instead of SVN? I really don't like messing with SVN most of the time..
A500:Rev6|+512K|ACA500+|C1084S
i386:Am386SX25|4M|GD5402|ES688|MuntPi3
i486:U5S33|8M|GD5428|YMF719|DB-S2
i586:P133|32M|T64+/MX2|V1|CT3980/32M
i686:K6-2/400|128M|V2/SLI|CT4520/32M
S370:P3-1200|384M|GF4-4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby nukeykt » 2018-3-30 @ 11:09
appiah4 wrote:Can this be somehow used with the stable branch of Dosbox instead of SVN? I really don't like messing with SVN most of the time..
Yes. But you have to apply these changes to the source code manually.
nukeykt
Postby appiah4 » 2018-3-30 @ 11:15
This would go way above my head I'm afraid. Would be very glad if you can build the patch for the stable version as well :) Thanks anyway.
User avatar
appiah4
Postby nukeykt » 2018-3-30 @ 11:22
appiah4 wrote:This would go way above my head I'm afraid. Would be very glad if you can build the patch for the stable version as well :) Thanks anyway.
I'll give a shot then.
nukeykt
Postby nukeykt » 2018-3-30 @ 11:52
Here's windows builds. I've accidantly attached older build above and can't edit it.
nukeykt
Postby Yesterplay80 » 2018-4-03 @ 11:16
Thank you, nukeyt! DOSBox ECE was updated with your new version, as of r4088.2 it now includes version 1.8 of your Nuked OPL emu.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby pnkiller78 » 2019-4-02 @ 18:15
Hi, I have a question?
Does changing the mixer rate affects in any way the other sound sources inside DOSBox (e.g. pcrate, gusrate, tandyrate)?
pnkiller78
Postby Taiyoumaru » 2019-4-19 @ 20:14
If I am to take the information provided by D-Fend Reloaded as accurate, then each individual sound module as its own sample rate except for Disney Sounds Source. https://gyazo.com/c656b6de5e16b84245f7c485be8acdfc
Taiyoumaru
Postby kila99 » 2019-9-08 @ 09:53
Great , thanks for update.
kila99
Previous
Return to DOSBox Patches
Who is online
Users browsing this forum: No registered users and 2 guests
