First post, by squareguy
There will be lots of photos coming in the near future.
I decided to build a new gaming rig that focuses on DirectX up to version 7.0 and also OpenGL 1.2. A Windows XP rig will handle anything newer and a "Time Machine" for anything older. It will handle late DOS games as well but that is not the focus.
Windows 98 Second Edition is the obvious choice for operating system and DirectX 7.0a will be installed. No other updates or service packs unless explicitly needed and they will be noted in this build log.
I ended up designing a system very similar to other things I have done but maybe with a narrower focus this time. I wanted a stable, non-fussy system and that lead me straight to the Intel 440BX chipset / Intel Pentium III combination. Overclocking is not something I care about at all for this type of system and with that in mind I chose the Intel SE440BX-2 motherboard. It is, in my opinion, a legendarily stable slot-1 motherboard that all others should be judged against. I already had a spare Pentium III 850-MHz Slot-1 CPU and decided to stick with it instead of using an adapter or hunting down something faster. I just got done RAM testing and ended up using 3 Micron 128MB, ECC, PC100, CAS2, SDRAM, double-sided DIMMs for a total of 384MB RAM. Why so much? Well, it's cheap, why not, it's stable, it's below the 512MB barrier and just in case I decide to load some really big sound fonts for late DOS gaming. So, this makes up the core system and I am happy with it.
Recap, parts thus far:
Intel Pentium III 850-MHz Slot-1 CPU
384MB RAM, 3 Micron 128MB, ECC, PC100, CAS2, SDRAM, double-sided Dimms
It might not be the fastest, sexiest or most exotic build but I think it will do a fine job, even if you think it might be boring hehe. I am trying to use almost all NOS, New Old Stock, parts and the pics will be coming soon.
Thoughts, comments?
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 1 of 48, by squareguy
I have decided on a video card. I have tried several for such a scenario and I will be using a NOS (New Old Stock, which I still have several) Nvidia Quadro4 380 XGL. If you are not familiar with this card it is the Quadro counterpart to the GeForce4 MX-440 video card. Basically think of it as a better, faster and lower power version of a GeForce2 Ultra. Although not period correct it fits perfectly with the intent. I am sure I will end up using driver version 45.23.
I do not think I will be adding any 3Dfx products in this build. I do think I will have a Voodoo1 paired with a S3 card or a Voodoo3 in my "Time Machine" build to cover DOS Glide games.
Windows 98 SE
Reply 2 of 48, by boxpressed
This is basically my "go to" box when I want to test a new piece of hardware or software. I can drop in a 266MHz P2 or a 1GHz CuMine or anything in between. Most of the time, I keep a 450MHz P3 in there with a quiet fan (the Intel stock fans are quite loud). It was fun to put together because most of the parts were new: case, mobo, CPU, FDD, HDD, DVD drive, etc. Just my video (GF4 Ti4600 and V3) and SDRAM were used.
SE440BX-2 builds are the Honda Accords of retro computers. Affordable, respectable, gets you where you want to be. Many of us have a classic and a hot rod to go along with it.
Reply 3 of 48, by squareguy
boxpressed,
It is a really good "go to" system for sure. I have built quite a few systems using NOS SE440BX-2 boards. I actually had to recently order more. The NOS boards are drying up. The ones I get are the correct revision to support Coppermine CPUs.
I got in a NOS Aureal branded Vortex 2 card today (8830A2 I think), very nice and have not unsealed it yet. Still waiting on a genuine Yamaha Waveforce 192 to arrive. I have several Turtle Beach Santa Cruz's in stock and I am trying to hunt down a YMF-744/754 card with SB-Link header. Not sure what I will be using for audio, one or possibly two cards. The Aopen Cobra cards on eBay do not appear to have the SB-Link header installed along with its associated parts. It might be worth modding one. It would need at least the header and two surface mount caps or resistors installed.
Windows 98 SE
Reply 4 of 48, by greasemonkey90s
I agree that the se440bx-2 is bulit proof but not all can support majority of cpus. My current se440bx-2 wont go past a p2 450 even after bios update. So it really depends on sn #. Otherwise there awesome.
Reply 5 of 48, by Andy1979
Good project. Intel boards of that era were great. Remember my AOpen 440BX Slot 1 board not being that stable, but my father had an intel built OEM Slot 1 board (440EX chipset I think, with Yamaha audio and 4mb Ati Rage graphics on board) which was rock solid.
I'm contemplating something similar for the same reasons - think I still have a PIII 650 s370 coppermine system in my parent's loft. It's either Intel 815 chipset, or a VIA equivalent from the same era. Graphics are a bit of a dilemma - on the AGP front I should have a 32mb Rage 128, 16mb Matrox G400 or a 64mb Radeon 9200SE to choose from. The 9200SE isn't really current for that system, but the other cards might be a bit slow. Geforce MX400 (or equivalent) is a good choice.
My Retro systems:
1. Pentium 200, 64mb EDO RAM, Matrox Millennium 2mb, 3DFX Voodoo 4mb, DOS6.22 / Win95 / Win98SE
2. Compaq Armada M700 laptop, PIII-450, Win98SE
3. Core2Duo E6600, ATI Radeon 4850, Win XP
Reply 6 of 48, by squareguy
Yeah they are fun and stable for sure. Boring is a good thing sometimes.
So, when you guys are doing a build do you ever get the "it's never good enough" syndrome? I am having to keep my OCD in check.
I have rethought the RAM situation and I am not going to be using any soundfonts so it will have a single stick of 128MB.
Windows 98 SE
Reply 7 of 48, by squareguy
Keeping it simple is very trying at times. The urge to keep making it faster would turn it into something it should not be.
With the theme of keeping it simple I have decided to use a new 120GB, 7200RPM, 2MB cache hard drive.
Windows 98 SE
Reply 8 of 48, by buckeye
I'm also building an P3 800 based system but undecided on the video card. Is the Quadro4 380XGL on par with a GF2 GTS as far as "eye candy" is concerned? Tried to snag some voodoo's but they're demanding too much coin!
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 9 of 48, by squareguy
Well the MX440 / 380 GLX are just as good visually if not better. On paper a Geforce2 Ultra is faster but in actual games the Ultra loses.
Windows 98 SE
Reply 10 of 48, by squareguy
Not much free time and slow progress 🙁 but some pics are coming and I got a chance to test the video card's RAM.
Windows 98 SE
Reply 11 of 48, by Kamerat
I had luck with older BIOSes for Coppermine, but newer ones failed. Try the P13 one.
YouTube channel
Reply 12 of 48, by squareguy
The Coppermine Pentium III 850 is the fastest officially supported Coppermine CPU on the right revision boards. I have P17, the latest, on mine and it's good to go. I do recall having to do that back in the day with a Powerleap 1400 though.
Windows 98 SE
Reply 13 of 48, by squareguy
Here is the info on Pentium III CPU's and the SE440BX-2
The following board revisions (AA numbers) support these processors:
754552-200 or later
754558-200 or later
A01450-200 or later.
850 MHz 100 MHz 256 KB P14 or greater
800 MHz 100 MHz 256 KB P14 or greater
750 MHz 100 MHz 256 KB P14 or greater
700 MHz 100 MHz 256 KB P14 or greater
650 MHz 100 MHz 256 KB P14 or greater
600E MHz 100 MHz 256 KB P14 or greater
550E MHz 100 MHz 256 KB P14 or greater
All board revisions support these processors
600 MHz 100 MHz 512 KB P12 or greater
550 MHz 100 MHz 512 KB P07 or greater
500 MHz 100 MHz 512 KB P07 or greater
450 MHz 100 MHz 512 KB P07 or greater
Windows 98 SE
Reply 14 of 48, by Kamerat
That's nice, I got the wrong revision of the board apparently. I have run Klamath, Deschutes, Coppermine, Tualatin, Samuel-2 and Nehemiah with the P13 BIOS so it's ok for me, the lack of 133MHz bus setting annoys me more (can use SoftFSB but it's not very convenient and it lacks FSB/4 PCI divider).
YouTube channel
Reply 15 of 48, by squareguy
Well I have been promising pictures and this will at least get it started. Here is the unboxing of the HP Quadro4 380 XGL Video Card.
1.92 MiB
1.81 MiB
1.73 MiB
2.11 MiB
1.93 MiB
Windows 98 SE
Reply 16 of 48, by squareguy
2.42 MiB
2.53 MiB
1.8 MiB
Windows 98 SE
Reply 17 of 48, by squareguy
Unboxing the motherboard.
2.09 MiB
2.31 MiB
1.61 MiB
1.93 MiB
1.79 MiB
Windows 98 SE
Reply 18 of 48, by squareguy
1.84 MiB
3.03 MiB
Windows 98 SE
Reply 19 of 48, by squareguy
CPU: Pentium III 850
I have a 800 and 850 with identical heatsinks and fans. In the last photo you can see the plastic fan holder that I epoxied onto the heatsink and then the fan screws into that.
I think I found a case that is different from what I normally use and I might have to change heatsinks if I have clearance issues.
1.71 MiB
1.43 MiB
1.28 MiB
1.38 MiB
Windows 98 SE
