I've been testing the machine for over a month now, and the CPUs seem to be stable. In the meantime I've also done a couple of things: I finally changed the case, and I looked into some RAM issues I've had in the past.
RDRAM Trouble
Previously in this thread I had stated that 40 ns RIMMs made the machine unstable. This was my theory at the time, and I had no reason to suspect the CPUs since I was running 933 MHz CuMines. I went through the trouble of acquiring 2 GB of PC800-45 RIMMs, with ECC, and even though they worked ok for a while, they seem to be giving me grief lately. Here's where I stand:
- 2 GB (4x 512 MB) of PC800-45 w/ECC are unstable, crash the machine upon boot-up or AIDA64's stability test, single-bit and double-bit ECC errors reported in BIOS,
- 2 GB (4x 512 MB) of PC800-40 w/ECC behave the same as previous ones,
- 1 GB (2x 512 MB, 2x CRIMM) of PC800-45 w/ECC are rock solid (memtest runs forever, AIDA64's stability test runs forever, no ECC errors reported in BIOS, etc),
- 1 GB (2x 512 MB, 2x CRIMM) of PC800-40 w/ECC are ALSO rock solid, like previous ones
I suspected power supply, so I unplugged EVERYTHING, and using a 600EB CuMine, a Radeon 9100, and a SATA-IDE bridge for my SSD I tested the memory configurations: same deal. Filling up the 4 slots will make the machine lock up due to ECC errors, using only 2 RIMMs and filling up the other slots with CRIMMs renders the machine completely stable. While everything was out of the machine, I ran another ram test:
- 1.5 GB (2x 512 MB, 2x 256 MB) of PC800-40 w/ECC disabled (256 MB sticks don't have ECC, so BIOS disables it) are also "stable": no errors are reported in memtest and it can run forever, AIDA64 stability test runs forever, etc.
I don't know what to think now. Either the machine dislikes having 2 GB, or it dislikes ECC, or both. Has any of the other OR840 users had trouble with 2 GB of RDRAM? I would appreciate any input on this.
New Case
Right, onto more joyful topics.
In the first post I said I really liked working with modern cases because of the "extras" they have. In particular I like cases with small footprint, grommets and PSU shrouds like the Fractal Design Define C, or the NZXT S340. The problem with those—at least for retro systems—is the lack of external bays, so I was reluctant to get one for this build. By chance I found out about Chieftec's AL-01B-OP and it had everything I wanted: small outside, roomy inside, full lenght psu shroud, grommets, lots of cable managing, and the all important(?) 5.25 drive bay. I was unsure due to no online reviews, but I went for it anyways. The machine currently has the dual 1400 Tualatins I worked hard to get to work, 1 GB of RDRAM, a GeForce 6800, a Voodoo2 SLI set (with home-made SLI cable 😀 ), an Audigy2 Zs (with home-made front panel cable 😁 ), and a USB2 card with front panel connectors. Two 14cm intake fans in the front to keep the Voodoos cool, a 12cm exhaust in the back—with a homemade airduct not pictured 🤣—to keep the Tualatins cool. I know some might dislike not using a true retro case for this project, but I really like the case!
Let me know what you think about it and if you have any suggestions.
The attachment 04865.jpg is no longer available
The attachment IMG_20170811_104516.jpg is no longer available
The attachment IMG_20170811_104253.jpg is no longer available
The attachment IMG_20170811_102548036.jpg is no longer available
The attachment IMG_20170811_102647223.jpg is no longer available
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
